Mikez655 6 #1 Posted July 4, 2012 Anyone ever hear of it? There's a gentleman on eBay selling one saying its very rare Share this post Link to post Share on other sites
Hodge71 690 #2 Posted July 4, 2012 :confusion-confused: Tillotson carbs really arent rare. He might have a rare model. I have a Tillotson carb on my Stihl chainsaw and I believe they make carbs for Harleys and also racing go-karts. You might want to see if they have a website and check the model number on there to see its rarity. Share this post Link to post Share on other sites
racinfool40 203 #3 Posted July 4, 2012 I think the Tiltson the guy is referring to is the one used on the 633 model wheel horse...when I got my 633 it had been switched over to the Carter Model N..and after talkin to a few members I'm gonna leave it that way..and have never found a complete set up to switch back...the listing is for the carb only and you would need to find the elbow and air cleaner assembly plua all the other linkage... MIKE Share this post Link to post Share on other sites
Kelly 1,033 #4 Posted July 4, 2012 The tillotson carbs used on the WH tractors are getting hard to come by, and parts are also, not sure of all the model tractors that used them but it was only a few in the early 60's Share this post Link to post Share on other sites
Hodge71 690 #5 Posted July 4, 2012 I never knew that some horses had them....very cool info..Thanks Kelly and Mike Share this post Link to post Share on other sites
buckrancher 2,695 #6 Posted July 4, 2012 the tillotson carb on a wheelhorse 633 is a model E12 and the fuel inlet is positioned 90 degrees from the one on E-bay and the throat dia. is way to small. It could be off a surburban 550 which is a E9 if I remember correctly but from looking at the pictures the throat dia may be even smaller (E5) so it may not be from a wheelhorse Brian Share this post Link to post Share on other sites
joebob 45 #7 Posted July 4, 2012 buckrancher is right about everything but the size its only a E3, Share this post Link to post Share on other sites
Coadster32 793 #8 Posted July 5, 2012 I have one on my 551. The motor was off an old ariens snow thrower. I was just happy to get the H55D of any kind. I've cleaned it out, but it leaks like a pig. I shut off the gas and run the carb dry every time I use it. Haven't gooten around to rebuild yet, or find the parts for it. How big would the throat be so i would know whick one I have? Share this post Link to post Share on other sites
buckrancher 2,695 #9 Posted July 5, 2012 buckrancher is right about everything but the size its only a E3, thanks joe :thumbs: Share this post Link to post Share on other sites
WH Raider10 17 #10 Posted July 5, 2012 I had a Tillotson carb on my 100cc 2 stroke racing gocart. Share this post Link to post Share on other sites
buckrancher 2,695 #11 Posted July 5, 2012 I have one on my 551. The motor was off an old ariens snow thrower. I was just happy to get the H55D of any kind. I've cleaned it out, but it leaks like a pig. I shut off the gas and run the carb dry every time I use it. Haven't gooten around to rebuild yet, or find the parts for it. How big would the throat be so i would know whick one I have? Chis the model number should be molded in the side of the carb E? I can make new bowl gaskets for these carbs Brian Share this post Link to post Share on other sites
Coadster32 793 #12 Posted July 6, 2012 Thanks Brian. I am hoping to get to it soon, as it's leaking down alot. I got some nice gasket material from Wallfish, but not sure if it's the fill valve leaking down. Looking to get a good rebuid kit before I rip into it. Just haven't looked yet. I'll keep your help in mind if I get into a jamb. :thanks: Share this post Link to post Share on other sites
rydogg 186 #13 Posted July 10, 2012 My tilly carbs on my horses are the following sizes Suburban 550 E10A 633 E11A I have a k141 that was not in a wheelhorse that has a E12A carburetor I also purchased a tilly from ebay that has a red air cleaner that I am assuming is from a wheelhorse the number on that is E12A. Are the different numbers for the throat size bigger number bigger throat?? Share this post Link to post Share on other sites
buckrancher 2,695 #14 Posted July 10, 2012 My tilly carbs on my horses are the following sizes Suburban 550 E10A 633 E11A I have a k141 that was not in a wheelhorse that has a E12A carburetor I also purchased a tilly from ebay that has a red air cleaner that I am assuming is from a wheelhorse the number on that is E12A. Are the different numbers for the throat size bigger number bigger throat?? yes Share this post Link to post Share on other sites
antiquetractors 4 #15 Posted July 10, 2012 Was this the carb you were talking about? http://www.ebay.com/itm/200786527178?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1497.l2649 I bought this carb for my 550 suburban. I think it should work but I have to get the motor going first lol Share this post Link to post Share on other sites
