rmaynard 16,835 #1 Posted July 3, 2012 I have a Charger 10. When checking the hydrostatic oil lever, do you read the dipstick after sitting it on the top of the pipe, or after having it screwed on? I know the engine oil is checked with the plug sitting on the block. Share this post Link to post Share on other sites
varosd 1,185 #2 Posted July 3, 2012 Bob, not sure on the sunstrands but on the Eatons , have you seat the dipstick in like you were going to leave it then remove to read it. sunstrands screw in like the Kohler engine oil dipstick? Share this post Link to post Share on other sites
rmaynard 16,835 #3 Posted July 3, 2012 Yes, my Sundstrand screws in like an old Kohler engine. There is probably 3/8" difference between sitting on top, and screwed on. Share this post Link to post Share on other sites
Martin 2,133 #4 Posted July 4, 2012 ive also wondered this myself bob........ i check and adjust the same way as on the engines, id rather have it up a little more than down. i dont think that it matters too much as long as its in the range on the stick. ive never read anywhere how its supposed to be checked...... :confusion-scratchheadblue: Share this post Link to post Share on other sites
stevasaurus 23,558 #5 Posted July 4, 2012 I go by the logic of the animal...if the dip stick screws in, set it on top and read it. It just does not make any since to screw in a dip stick to get an accurate reading. My 2 cents. :) Share this post Link to post Share on other sites
rmaynard 16,835 #6 Posted July 4, 2012 Well I filled it to just below the "F" level with the dip stick sitting on top. It took four quarts. Seems to run just fine. Actually, it runs much better with the new filter and fresh Dexron. Replaced both axle seals and no more leaks. Grandsons are coming over today, so the Charger is refreshed and waiting for them. 1 Share this post Link to post Share on other sites
stevasaurus 23,558 #7 Posted July 4, 2012 Sounds great Bob...wish it was cool enough to run a tractor around here. I have not even mowed the grass in 3 weeks and it still does not need it. Maybe a trip around the block. Have fun today. :) Share this post Link to post Share on other sites
varosd 1,185 #8 Posted July 4, 2012 great job Bob! you might need a sun canopy today!! Steve, your "cool" looking avatar is looking better and better. Whew it's hot! 1 Share this post Link to post Share on other sites
rmaynard 16,835 #9 Posted July 4, 2012 great job Bob! you might need a sun canopy today!!We live on a wooded lot. Temperatures here are generally about 10° to 15° cooler than out in the sunny areas. Though I curse the leaves when they fall in autumn, I praise them on a day like today. Share this post Link to post Share on other sites
squonk 45,271 #10 Posted July 4, 2012 Boy do we need RAIN!! I always wondered how they play tennis on grass at Wimbeldon. Now I know. My yard is as hard as concrete! Share this post Link to post Share on other sites
varosd 1,185 #11 Posted July 4, 2012 we did get some rain last night..need more! Share this post Link to post Share on other sites
stevasaurus 23,558 #12 Posted July 15, 2012 I actually found the answer to this question in print. I have seen it in the Tecumsah manuals, but here it is in a WH manual. This is in the "1979 B, C, D" Owner's Manual on page 15 in parentheses....(dipsticks with threaded plugs should NOT be screwed back in when checking oil level.) :) The stick should be inserted with the plug resting on the top. Share this post Link to post Share on other sites
varosd 1,185 #13 Posted July 15, 2012 I actually found the answer to this question in print. I have seen it in the Tecumsah manuals, but here it is in a WH manual. This is in the "1979 B, C, D" Owner's Manual on page 15 in parentheses....(dipsticks with threaded plugs should NOT be screwed back in when checking oil level.) :) The stick should be inserted with the plug resting on the top. Steve, Bob was looking for the proper way to check hydro tranny oil , did you find anything relating to this? I know my Kohler K-181 has that threaded dipstick system for engine oil. Is the hydro oil checked the same way in a Charger 10? :rolleyes: Share this post Link to post Share on other sites
stevasaurus 23,558 #14 Posted July 15, 2012 Don, I would say so. It just does not make since to me to screw back in a dip stick to get an accurate reading. Share this post Link to post Share on other sites
varosd 1,185 #15 Posted July 15, 2012 I guess that was a cheaper way instead of a pull and look system?. I just don't like having the chance of gummed up threads or something dropping in...especially a Hydro! ^_^ Share this post Link to post Share on other sites
stevasaurus 23,558 #16 Posted July 15, 2012 Yes...you want to thoroughly clean around the plug before you pull it out and clean the plug threads before you put it to sleep. Share this post Link to post Share on other sites
rmaynard 16,835 #17 Posted July 15, 2012 I'm not going to stress over it. I am in the "range" delineated by the cross-hatches, it works fine and life is good. :icecream: Share this post Link to post Share on other sites
stevasaurus 23,558 #18 Posted July 15, 2012 Glad you are not stressed out Bob. It was your thread and the issue has come up before, I just happened to find the answer in print in a Wheel Horse manual...sorry I helped out. :) 1 Share this post Link to post Share on other sites
JimD 3,347 #19 Posted July 16, 2012 Thanks for finding that Steve, I've often wondered about this . :teasing-tease: Share this post Link to post Share on other sites
Buckshot 1 15 #20 Posted July 19, 2012 :handgestures-thumbupright: Thank you Steve. I had better check the fluid level on my newly installed 8 spd. in my 656, as I screwed the dipstick in after adding fluid to check the level. :flags-usa: Share this post Link to post Share on other sites
