tomtractor 71 #1 Posted June 29, 2012 Can the older style thinner ag/rims tires fit on a C125? The C125 has wider tires? Any thoughts? Share this post Link to post Share on other sites
Sparky-(Admin) 26,272 #2 Posted June 29, 2012 If you mean the 6x12's then yes they will fit. The bolt pattern is the same. The tires will be way under the fender tho. Mike............... Share this post Link to post Share on other sites
tomtractor 71 #3 Posted June 29, 2012 Does it look stupid? What are the pros/cons to using them - if any? Share this post Link to post Share on other sites
bo dawg 640 #4 Posted June 30, 2012 I think the wider looks better, hefty. But I have noticed that the thinner ags get better traction. Share this post Link to post Share on other sites
rwilson 128 #5 Posted June 30, 2012 wider is not always better Share this post Link to post Share on other sites
baerpath 517 #6 Posted June 30, 2012 wider is not always better I resemble that remark lol I'd stay with 8,50 or wider for stability Duane Share this post Link to post Share on other sites
HorseWhisperer 243 #7 Posted July 1, 2012 (edited) Duane-9.5.3.10.54 weights.Don't make me call!In the great words of Yogi Berra Money is as good as cash!Tom,wider is great on dry grass,sand and most mud!6x12 is GREAT for snow and real traction-smaller contact patch=more pressure and more traction!I just changed the tires from 6x12 to 12x12 for summer! Edited July 1, 2012 by commandomayo Share this post Link to post Share on other sites
bean 85 #8 Posted July 2, 2012 I'm the opposite. I like the thin look. if you get deestone 23x8.50-12s and install them on an older 5" wheel, they are just a little bit larger than a 6-12. I am i the process of doing that on my 310-8. I am putting narrow suburban style front wheels on it, also. I will post some pics when I get done. the thinner tires, along with wheel weights, will give you the best traction in anything but pure sloppy mud. Share this post Link to post Share on other sites
