Electro12WH 50 #1 Posted July 16, 2008 The trans in question has a problem with third gear. If the engine is off, the shifter won't go in third. If the engine is running, it grinds an won't go in. I know about having to have the belt guard on. That's not it. I'm considering openning the trans case. I don't have a manual for this. Will parts come tumbling out? Which side of the case should be down when I open it? Thanx! Rich Share this post Link to post Share on other sites
TT-(Moderator) 1,185 #2 Posted July 16, 2008 Follow this LINK (enter the model number for your tractor) and select the "MANUALS" tab. Select the 6 & 8 speed transmission repair manual .pdf download and save it to your computer. (the info for your #5053 3 speed Uni-Drive is there.) Not sure if I "got you" yet or not, but B) Share this post Link to post Share on other sites
