dave in A.P. 4 #1 Posted June 19, 2012 fuel started leaking from the pulse pump on the 11H.P. briggs in my GT-1100. When I removed the pump, the plastic elbow on the back side of the pump that goes to the carb has cracked where its pressed on to the alum. tube that fits in the body of the pump. Tried to JB weld it ,it lasted about 20 min then started to leak again. 2 shops in my area say you can't buy this pc. Briggs wants $80.00 for this pump. Any idea's? Has anyone put a low pressure electric pump on something like this? Share this post Link to post Share on other sites
bowtiebutler956 650 #2 Posted June 20, 2012 You can buy a universal pulse pump of pretty cheap. They use them on racing go carts, and other applications, but it would not be a direct replacement, you would probably have modify a little. Matt :flags-texas: Share this post Link to post Share on other sites
TT-(Moderator) 1,170 #3 Posted June 20, 2012 I second Matt's recommendation to continue using a pulse pump - especially on an engine that's already set up for one. I just ordered a few of these today at work: LINK Share this post Link to post Share on other sites
dave in A.P. 4 #4 Posted June 20, 2012 Thanks guys, on a engine this small,are all these "pulse pumps" of sufficent capacity? the one on TT's link looks nothing like what I have, but fabricating a bracket is to make it shouldn't be to bad. Is there a certain way these go ? Vertical or horizontal matter? thanks dave Share this post Link to post Share on other sites
TT-(Moderator) 1,170 #5 Posted June 20, 2012 The pump in my link is more than adequate for your engine. Mounting orientation does not matter. Share this post Link to post Share on other sites
Rooster 192 #6 Posted June 21, 2012 These are the same pumps I use to feed high cube high output race engines, they are more than adequate for your 11HP. As a matter of fact, on some engines we restrict the pulse line or they will over feed the carb. BTW, do you have a pic of what broke..I may have the parts you need.... Share this post Link to post Share on other sites
