Jumo 0 #1 Posted June 4, 2012 When I moved in the house I’m living in now I struck a deal with the PO to purchase his 520H. I wanted it because he had a tiller hooked up to it. I liked my C100 so much I figured the 520H must be a dream. I was right. I’ve now got a big garden thanks to the tiller and I’ve been looking for more toys. I recently had the picked up a cultivator, disc and plow for my 520H. All of them are Brinly sleeve hitch implements. I first hooked up the cultivator and noticed the unit got stuck in its up position. The PO had only hooked up a cable directly to the tiller and never got a rock shaft. I figured the lack of a rock shaft must be my problem and it was causing my cable to get hung up. So last weekend I decided to make a rock shaft and set up the cable lift correctly. Well after some digging into the project I found a mess. The cable wore completely through the guide tube and began cutting in to the hydrostat. Besides all the wear that’s obvious from the cable rubbing, look where the arrow is pointing. It is about 5/16†deep into the casting and began touching the case bolt. I’m not sure how much longer I could’ve went before I dropped all my fluid. Here’s a shot of the guide tube. This is where it wore through and started chewing at the casting. This is the wear I could see with the guide tube still installed. At first I thought it was a split tube. This is the replacement guide tube I made. This is the rockshaft I fabricated Here’s a shot of my homemade sleeve hitch. I saw some guys have just hooked up the cable directly to the implements. You may want to keep an eye on it. I tested it this morning and my set up works like a charm. I cultivated my garden and now its time for the 520 to get a bath. Share this post Link to post Share on other sites
Kelly 1,028 #2 Posted June 4, 2012 I just this weekend pulled a rockshaft and lift cable off a eaton trans tractor, the lift cable wore all the way through the cable tube also, almost split the tube in half from end to end, it cut into the pump case but no leaks so I guess this one was caught in time also. Share this post Link to post Share on other sites
Sparky-(Admin) 19,656 #3 Posted June 4, 2012 If the hydro isnt leaking maybe its time to fill the grove with some JB-weld. Mike....... Share this post Link to post Share on other sites
Don1977 604 #4 Posted June 5, 2012 It might be time to reengineer that a couple of small pulleys to keep it off the pump case. Share this post Link to post Share on other sites
1maidenfan 201 #5 Posted June 6, 2012 Nice fabrication work :text-bravo: Share this post Link to post Share on other sites
smoreau 658 #6 Posted June 6, 2012 It's amazing how much a cable can cut through and not show any wear. I have often wondered if the cable would do that to a lift tube. Nice fab work on the rock shaft and hitch! :handgestures-thumbupright: Share this post Link to post Share on other sites
