darren 49 #1 Posted June 4, 2012 Could someone confirm how the plastic blocks that support the slider for the idler pulley on a 48" deck fit? I'm pretty certain the very thin plastic piece sits underneath and the thicker 'n' shaped piece clamps over the slider from the top. I checked the parts diagram but it doesn't show in enough detail and I rather stupidly didn't take a picture when I took it apart.. If this makes no sense, I can try andget some photos of the pieces in question. Share this post Link to post Share on other sites
Trouty56 567 #2 Posted June 4, 2012 I'm sure you are right. The thin piece is to reduce friction on the bottom. Share this post Link to post Share on other sites
darren 49 #3 Posted June 4, 2012 Thanks Bob, I thought as much :thumbs: Share this post Link to post Share on other sites
Lars 526 #4 Posted June 4, 2012 Yep thats right Bob... Share this post Link to post Share on other sites
Don1977 605 #5 Posted June 4, 2012 That the way it goes. You can also turn the blocks around if they are worn on one side. It wares one side closer to the idler and the other side at the end. I wore out both sides of mine. When I rebuilt my deck they were not avaibable. I had pick up some scrap nylon from an old mill site I was drawing a site plan for. Had a friend with a milling machine to make a couple top bocks. the bottom thin ones I got from Toro. Share this post Link to post Share on other sites
darren 49 #6 Posted June 4, 2012 Thanks guys :handgestures-thumbsup: Share this post Link to post Share on other sites
