Buckshot 1 15 #1 Posted June 3, 2012 On all the k-seires I have worked on the governor shaft had a c-clip to keep it from pulling thru the brass nut. I ordered a new governor shaft for a K 301 I am rebuilding and the new shaft came with a spacer and no c-clip. No instructions on which side of the shaft the spacer goes, cly side or block side. Has anybody run into this, if so which side? Any ideas/suggestions will be greatly appreciated. Thank you for your time. Share this post Link to post Share on other sites
TT-(Moderator) 1,162 #2 Posted June 3, 2012 I have never seen a K series with a c-clip on the governor shaft. Cross shaft goes in block, then the spacer, then the brass (bushing) nut. Share this post Link to post Share on other sites
can whlvr 994 #3 Posted June 3, 2012 me either,non of mine have a clip Share this post Link to post Share on other sites
Buckshot 1 15 #4 Posted June 4, 2012 Thank you guys for your replies. I am surprised that no one has seen a governor shaft with a c-clip. TT, your information is very helpful. when I get my block back from the machine shop, I can get back on my rebuild. If i could fiqure out how to post pictures I will put one up of the shaft with the c-clip. Share this post Link to post Share on other sites
WHEEL HORSE BILL 7 #5 Posted June 4, 2012 Show us pictures so we can see what your dealing with.I never saw a c clip on the governor shaft. Share this post Link to post Share on other sites
