can whlvr 991 #1 Posted May 30, 2012 so my 1989 414 was running rough,so i thought i will pull the carb and clean her up,i take her off and apart,and i look at the jet in the middle,(ive read on brian millers site no need to remove)and think i should drive that out from the top to clean and soak it,well this turned out to be a really bad idea,the jet is not like a removable one from my older k series,its a connector tube to the hole in the top of the carb body,so i completely wrecked the top of the tube and also the seal it has on the top of the tube,but i noticed that the throttle shaft is loose at both ends,any one ever reinstall this tube if its even available anymore with good results,i have a spare carb from an older kohler,so im not stuck but i dont want to be left without a spare carb on the shelf,its handy,anu input appreciated,or will i have to send her to brian miller,or buy a used one,or a new one from ebay??? Share this post Link to post Share on other sites
CRE1992 135 #2 Posted May 30, 2012 I can get a new Kohler Carter Carb for $140ish. However I don't know how much shipping would be. Share this post Link to post Share on other sites
SousaKerry 500 #3 Posted May 30, 2012 plenty of used ones to be had, post a wanted in the classified section Share this post Link to post Share on other sites
Kelly 1,028 #4 Posted May 30, 2012 I have a box of used carbs what are you looking for??? Share this post Link to post Share on other sites
can whlvr 991 #5 Posted June 2, 2012 sent a pm kelly Share this post Link to post Share on other sites
