Terry M-(Moderator) 2,303 #1 Posted May 21, 2012 Does any body have / or is willing take and send me a nice clear picture of how the governer linkage is connected between the carb. and governer arm on an HH60 tecunseh engine. any help appreciated. Thanks, Terry Share this post Link to post Share on other sites
AMC RULES 37,259 #2 Posted May 21, 2012 Will this help you? :scratchead: 1 Share this post Link to post Share on other sites
Terry M-(Moderator) 2,303 #3 Posted May 22, 2012 Yes it does! Thanks craig. But carb is a little different, it has a spring between the the throttle plate connection and where the throttle cable hooks-up. working tonight so I will take a picture of mine tommorrow afternoon to show you (and me). Thanks again :) Share this post Link to post Share on other sites
Terry M-(Moderator) 2,303 #4 Posted May 22, 2012 Craig, Found a minute , Here are some pictures I took. What do you think? would that missing governer link connect in the same hole as the spring on the carb? Share this post Link to post Share on other sites
AMC RULES 37,259 #5 Posted May 22, 2012 Is that a fixed point the other end of the spring is attached to? :scratchead: Share this post Link to post Share on other sites
AMC RULES 37,259 #6 Posted May 22, 2012 Here's another image for you Terry. Share this post Link to post Share on other sites
305 381 #7 Posted May 22, 2012 you need a rod going from the govenor arm to the little hole on the throttle arm right behind the spring. that is how both of my H60s are setup. they are easy to make out of 1/16" tig welding rod Share this post Link to post Share on other sites
wallfish 20,159 #8 Posted May 23, 2012 Diagram of what 305 posted Share this post Link to post Share on other sites
wheelhorse656 20 #9 Posted May 23, 2012 I'll put a pic of the diagram up tomorrow. If still needed Share this post Link to post Share on other sites
Terry M-(Moderator) 2,303 #10 Posted May 23, 2012 Thanks guys. Thanks for the pictures Craig! Nice Diagram Walfish, 305 I'll try to find some tig rod adound the shop first but I was wondering, would it be smart to replace the spring? Now I just need to make or find a govenor link piece. looks like parts tree has them. Share this post Link to post Share on other sites
wheelhorse656 20 #11 Posted May 23, 2012 Terry I would get the spring and the correct one tecumseh because it has a proper lenght and tension which help it work correctly, I have a linkage piece and the springs the springs are 2.50 and the linkage Ill throw in for free I have a couple of good used ones out in the barn.... Share this post Link to post Share on other sites
Terry M-(Moderator) 2,303 #12 Posted May 24, 2012 Here's another image for you Terry. Craig, where does your throttle control cable attatch to the carb? Share this post Link to post Share on other sites
Terry M-(Moderator) 2,303 #13 Posted May 24, 2012 Terry I would get the spring and the correct one tecumseh because it has a proper lenght and tension which help it work correctly, I have a linkage piece and the springs the springs are 2.50 and the linkage Ill throw in for free I have a couple of good used ones out in the barn.... Jordan, Sent you a PM Share this post Link to post Share on other sites
AMC RULES 37,259 #14 Posted May 24, 2012 Best I can do for you right now Terry. Share this post Link to post Share on other sites
Terry M-(Moderator) 2,303 #15 Posted May 24, 2012 Good Pictures Craig! I was just looking at your first pic of the carb and wondering where the throttle cable came into play. I can see it now , Thanks Share this post Link to post Share on other sites
