JamesBe1
D-Series Headlight Gromets
JamesBe1
So, since I have my tractor in pieces to replace the engine, I figured I would strip and paint a bunch of parts. I took the headlight assembly apart, and was going to strip and repaint it, but the paint wasn't really all that bad. Also the decal and pinstriping were in good condition too. I decided to just mask them off and repaint after a good cleaning.
The headlight bezels were a different story. They had a fair amount of overspray from previous paint jobs. Some of it was blue paint. There was also oxidation of the rubber, but no dry rot at all. After enquiring in one of the threads about restorer/protectant, Andy (wheelhorseman) recommended silicone grease from the hardware store. I didn't have any on hand or feel like buying some, but I had a tube of vacuum grease around. I figured it was close enough.
Here are the shots of before and after I tried removing the overspray with WD-40. That myth is busted as far as I'm concerned. I had to use a sanding pad and dishwashing soap with hot water to get most of it off.
Here are some shots of before and after the vacuum grease treatment. Not too bad, but we'll have to see how it hold up.
Here are some shots of the bezels back in place with the lights installed.
Here is the assembly back on the tractor. I shoulda wiped the dust off of the grill before taking pics. Sorry about that.
So, what do you all think?
KC9KAS
Looks nice and shiney!
Those "D's" just look so massive!
wheeledhorseman
You've done a good job there James and they've come up well.
Easily overlooked and after all, if you ain't makin' dust then you ain't working hard enough!
(At least the grille's on square - I famously photographed my 'D' for the resto thread not realising that I hadn't put the grille back on properly. Doh!
Andy
1maidenfan
Looking good :banana-wrench::handgestures-thumbupleft::happy-smileygiantred::text-bravo::omg::woohoo: :wicked:
312Hydro
Looks great! Those "D"s are sure growing on me!
  • Similar Content
    • BuffaloD200
      By BuffaloD200
      Finally getting around to working on my ark loader.  The previous owner said he thinks the problem is with the spool valve.
      As I've learned a bit more about hydraulics now, I'd like to get this all sorted out.
      I noticed the power beyond port is connected to the reservoir return.  Is that right?
      Anyone see anything blatantly incorrect?
    • tractorboy79
      By tractorboy79
      I was looking around on ebay and noticed that hydraulic actuators from John Deere 312, 317, etc models appear to be Identical to a Gt14 or d series lift cylinder. My question is would a new cylinder from ebay be able to replace one that is on a gt14 or d series?
      Images below of cylinders to show similaritys.
    • BuffaloD200
      By BuffaloD200
      '74 D-180
      My friction disc in gone on my clutch.  I saw the old post about making a new friction disc, so I'm not concerned about that.
      I managed to remove the front clutch plate and double v-belt pulley.  But I can't separate the two.  When I took the assembly off the spiraloc washer popped off on its own.  I HAVE READ THE MANUALS.
      So I should be able to just remove the pulley from the front clutch and continue with step 4.  The v-belt pulley is loose as all hell and flops around like a dead fish.  It seems to be hung up on a ring or bearing race.
      So my thoughts are grab a BFH or sparky the blue tip wrench.
      Is there an unpublished step 3.5, or some trick?
    • BuffaloD200
      By BuffaloD200
      Hey all,
      My '74 D180 has a lot of trouble pushing snow.  Weighted tires, but nothing else at this time.  I've found it gets stuck frequently and only one wheel spins.  Do these tractors not have a limited slip/locker arrangement?  How does everyone manage with the infamous one wheel peel?
    • BuffaloD200
      By BuffaloD200
      Hey all, I need to install a drive belt on my 75 D180 for my snowblower.  I've looked through a bunch of D-series owner's manuals, and none seem to mention replacement procedure.  The PTO pulley is fixed, save for engaging the PTO and there is minimal movement at the snowthrower pulley. There's no idler or tensioner as far as I can tell.  Do I have to remove the PTO pulley?  That seems to be a required service item.
      Same question for my 80 D200 as well really.
      Using the recommended 4L490W belt.
      Thanks
