Hammerhead
Early production RJ35 question
Hammerhead
My early production RJ35 has only one hole in the frame where the muffler pipe crosses the vertical frame peice. Most all RJ's I've seen have 2 holes there for a U shaped muffler clamp type of bolt. Is there a single hole version that just loops over it and only bolts on with one bolt? 026-4.jpg041-2.jpg043-1.jpgThanks in advance for your info on this matter....Hammerhead :popcorn:
VinsRJ
Looks to me like the place where the second hole for the exhaust loop would be is missing? I don't know of a single mount style, may be Clay or Papke would know?
buckrancher
I agree with Vince looks like they cut thru where the other hole should be
Brian
wallfish
That's a first, not enough holes drilled into an old RJ
rj35hunter
From what I have seen all rj35 models (except early gas tank stand models) have two holes drilled into the hood stand with the two hole pipe strap style clamp not the u-bolt style like used on rj58's & suburbans. Also the holes in a rj35 are one size smaller than in a rj58 or suburban, which have the larger holes. I've only seen two holes drilled into the hood stand on rj35 models that do not have the gas tank stand. When they have the gas tank stand the muffler comes straight off the engine instead of being piped to the front like most. I'll post some pics showing some of mine the way I got them & look to be original & untouched.....other than some missing the clamp & bolts, which you can see where a clamp used to be. I'll post them in order of production, starting with the 35's with gas tank stands & no holes, then 35's with no gas tank stand having the two holes. Last two is a 57 rj35 with a kohler instead of a clinton & last a rj58 showing the u-bolt. All of this is my opinion from my research. I posted several examples to show the pattern. Hope this helps!
Clay
  • Excellent 1
Hammerhead
Yes I guess I forgot to mention that the hack mark in the hood stand was about a half inch or more below where the bottom hole should have been, according to my 1958 style of U bolt clamp when placed up against the other hole. I took another pic of that, maybe that is better than the first pic. Thanks alot Clay for the awesome pics! You are the Man on this stuff! The problem with this early production RJ is it didn't come with an engine and the frame was cut in half and a couple 6 inch sections were added to make a dragster out of it. I added the RJ55, 56, or 57 Kohler engine (Model # K91-T, Serial # 390851, Spec.# 31307A). It does have the remnants of the gas tank stand, which I will have to fabricate the peices for that. See the pics of the stubs left on the hood stand and the frame. It also had the solid lift lever which is also gone, I will have to make one of those too. The hood is from an early 1955 RJ25 that I bought from Tim and Teresa of Mich. fame. It doesn't have the straps attached to it like the later one's, but you can see the impression of the gas tank from it being up against it for many years. So should I get a Clinton engine for this instead of the Kohler? I have heard that the Clintons came with the odd shaped (square-ish) gas tank. Notice too the lack of the brace on the rearend in the last pic, usually there is another peice of metal running on an angle to strengthen up the frame by the rearend housing.
55rj35jr
KEITH I'VE GOT A EXTRA GAS TANK FOR THE EARLY TANK FRAME STAND RJ IF YOU NEED ONE, CLAY KNOWS HIS STUFF YOU HAVE THE RIGHT GUY HELPING YOU...IN MY OPINION I'D GO WITH A CLINTON,THATS WHAT I HAVE ON MY 55 CABLE STEER.
rj35hunter
Thanks, 55rj35jr. I agree, the Clinton is more correct for the year of your tractor. I don't think they started using a Kohler until 57 & it would have been a K-90 instead of a K-91. At least I have not seen a Kohler on a RJ35 other than a 57 model. The engine on your 35 now is more than likely off a RJ58. The spec & serial # is very close to one of my original 58's. The correct Clinton engine should be a 1200 152 A series engine. Keith, the missing brace on the rear end is correct. That was not added until sometime in early 56. All of my 55's & a couple early 56's do not have it, but all of them after that do. I think it was added to take away some of the vibration in the variable speed pulley assembly. It took me a couple years of owning several RJ35's to even notice that! LOL Also, about your exhaust set up......I think someone added the hole you see in the hood stand now, because with yours being early with the gas tank stand it should be only a muffler on the engine & not piped to the front like the very first picture I posted earlier. There are so many variations & changes along the way from 55 to 57 that I don't think we will ever understand or figure out all of them. I just try to figure it out the best I can with what we have to work with, with the lack of facts & info.
Clay
  • Excellent 1
TT
For what it's worth, here's a picture of the Clinton gas tank:
Hammerhead
Ok thanks alot guys for helping out on this one. I do have another 1955 RJ35 with Kohler on it. It is pretty much an untouched original, there are some pics on this site and in my records here. I don't have the numbers from that engine available at this time, it is stashed under a ton of junk! I have some papers from WH from 1954 or 55 talking about, they had a problem with the Clinton engines and were demanding the situation to be corrected. Cool story, may have to dig them papers out for a look. Thanks TT for the pic, it shows alot of stuff I need to make! You are always ready with good pics, gotta love it! Hey 55rj35jr, I'd like to see pics of the tank and would buy it no problem! Thanks again! KJ
stevebo
I was told by a very reliable source that all early 55's had clintons only and if I am not mistaken the entire year. It was not until very late 55 or early 56 the kohler was used. I could be wrong about the second half but the early production models were only clintons.
Hammerhead
Yes I can believe it Stevebo, I'll have to track down a Clinton engine. I hope my other RJ35 is a later production '55, it has the black rear rims and the silver front rims and it did have the RJ58 style of steering wheel and not the cast iron one used by the older RJ's. That wheel doesn't fit on the shaft like it should, it doesn't go down so the top of the shaft is flush with the top of the steering wheel center peice. So there is a gap of about 3/8 of an inch. I don't know if any other 55's have that steering wheel and if so is there a gap like mine? Or should mine have the cast iron steering wheel?
But anywhoo, the hole in my early production RJ35's hood stand, will have to be welded up. It also looks like all of RJ35 Hunter's holes are drilled off to the left and not centered like my single hole. So I'll have to weld it up and grind it down.
The saga continues...KJ
rj35hunter
Keith, good eye on the offset of the hole for the exhaust. I had not noticed yet that they were originally offset..... :eusa-think: That would be a for sure sign the holes shouldn't be there. I saw your other RJ35 & that Kohler is a 4 HP that wasn't used until 58-60 with the oval 4HP decal location. I believe the RJ35's that had a Kohler were all K90 3.6 HP that had no decal like that, not K91 4 HP with the oval decal. On the steering wheel, that is a mystery too. I have an early 57 with the same issue......larger steering wheel with the end of the steering shaft below the rim of the steering wheel. What I have been told is that they were still using left over steering shafts from the earlier tractors that used the cast iron steering wheel & the hole for the roll pin was drilled in a higher spot or the shaft is a shorter length, which caused the issue of them not lining up. Either way it will not be flush together if you use a 57-up steering wheel on a 55-56/early 57 steering shaft. So my opinion is your tractor originally came with a cast iron wheel that was later swapped for the new/larger one, since your tractor is for sure not a 57. I have seen a couple other early 57's with the same issue too.
Keith your complete RJ35 with the deck we are talking about has stumped me for sometime whether its a 55 or 56. It has the larger 7" drive pulley like a 55, the extra brace on the drive pulley assembly like a 56, the front tires were the style BFG's you see on 56-58 & maybe someone painted the outside with silver paint sometime (would like to see what color the inside paint is). I would like to know which style rear hitch it had & the hole in the center of the frame right behing the engine where the lift cable would come out of.....what style it is, whether it's the large twisted style hole that had nothing to hold the cable or the smaller hole that used a flat metal clamp that bolted to the frame too right behind the hole for the cable to come through? If its the second style it will have two holes there, one larger than the other. With all that said, I think your complete RJ35 is a 1956 with some changes.....which is not bad, it looks great. Sorry to ramble on.....I just get into interesting info & facts on the early RJ's. :silence:
Clay
Tim LaPree
Keith, that hood was from an early RJ35. There were no tank straps because the tank sat on a hood stand. I believe the tank they used were quite common on the Wisconsin engines. The early ones also would have had a Clinton engine and the muffler was right on the engine. I believe some of the early ones with the Kohler K90 also had the muffler on the engine. I'm not sure if the K91 ever did.
VinsRJ
The fuel tank that sat on the early tank stands were a Clinton tank.
  • Similar Content
    • CasualObserver
      By CasualObserver
      Operator manual
      Illustrated parts list
      6 pages 3.73MB
      Illustrated parts list #A-7136
      Includes PSB #023 #052 #058 #060 #080
      10 pages 938.48KB
      Engines used according to Toro
      Clinton B1290-1107
      Kohler K91-31307A
      Kohler K91-31388A
      Electric start kit
      Electric starter kit model EC-35 for Clinton engine - Listed for 1958 and 1959
      Electric starter kit model EK-35 for Kohler engine - Listed for 1958 and 1959
      6-12 tire chains model TC-12 - Listed for 1958 and 1959
      Seat cushion Foam rubber with imitation leather cover model FC-24 - Listed for 1958 and 1959
      Transmission drive belt 1567 - (4L x 29" or 1/2" x 29")
      Details & Attachments
      2 pages 107.33KB
      1958 model RJ-58
      1958 serial numbers that have shown up for the RJ-58
      Early models used Kohler K90T-27107D equipped with a Schnacke recoil unit with a backup rope starter contained under the recoil assembly and an oil bath air filter.
      00005
      00251
      01099 - No casting date on trans. Leather gearshift boot, large, round rear wheel hubs, "slab" hitch, replacement engine
      01188 - Has round rear wheel hubs
      01516
      01636
      01768
      01789 - No casting date on trans. Leather gearshift boot, 3-ear triangular rear wheel hubs, "slab" hitch, Clinton engine with Schnacke recoil
      01797
      01871
      02525
      03177
      03501 - Located in UK
      03796 - Kohler K90T-27107D with serial 364044 equipped with a Schnacke recoil unit with a backup rope starter contained under the recoil assembly and an oil bath air filter.
      04041
      04883
      04885
      05000
      05619
      05714
      05798
      06528 - May be 16528
      06749
      06771
      07633
      07649 - Transmission J12-8 October 12, 1958
      07725
      08440
      08612
      09284
      09337 - Hard to read
      10163
      11432
      11628 - # 3521 spline gear with 10 splines changed to 11 splines in 5003 and 5010 transmissions at serial # 11628 PSB #023
      11916
      12221 - B3-9 trans casting date - Kohler K91 engine with Schnacke recoil
      12291
      14473
      14713
      16097
      16528 - May be 06528
      166x6
      16868 - F4-9 trans casting date - Kohler K91 engine with Fairbanks recoil, solid pan seat without holes
      18348
      June 2023
      18500 and lower
      Late 1958 units came with a Kohler K-91T-31307A equipped with a Schnacke recoil unit with a backup rope starter contained under the recoil assembly and an oil bath air filter.
      2 pages 106.94KB
      1959 model RJ-59
      1959 serial numbers that have shown up for the RJ-59
      Early 1959 units came with a Kohler K-91T-31307A equipped with a Schnacke recoil unit with a backup rope starter contained under the recoil assembly and an oil bath air filter.
      18501 and up - Possible 1100 units built
      20078 - Located in UK
      203xx
      21033
      292xx
      21900 - 1960 Suburban 400 began production at serial #21900 somewhere around Aug-Oct 1959.
      Late model RJ-59 tractors with a Kohler would have a K-91T-31388A with the Fairbanks recoil starter and paper air filter element. The 31388A was also used on the 1960 Suburban 400.
      K91T-31388A Serial 425251 found on RJ-59
    • bigbuck
      By bigbuck
      I'm not positive of the model, but I think I'm close. Please call George at 517-499-5678
    • RJcollector
      By RJcollector
      Ive been thinking about selling my 4 RJ-58s and all the attachments and parts I have. I have 4 tractors-2 have Kohler K91T , 1 has the Clinton and one has no engine. Only 1 is missing the serial number decal. Kohlers run. Clinton needs a carb. I have original exhaust shields AND belt guards for 3 of them. 3 mower decks, 2 plows, cart, 2 spare transmissions, parts breakdowns, original manuals and sale tags, seats, tires.  Not sure if I should sell it as 1 big collection or break it up. And also a good starting price?  I'll post pics when I get a chance. Thanks
    • Keaton
      By Keaton
      i do not know how to route this throttle cable on this RJ 59, i will attach some pictures, i watched packrats video on adjusting the govner on his 401, it did not look the same. also i think that and is way to long so that might be part of it. ( and also the color on that block looks beautifull) there is come pics, the more the better!
