AETD
B&S up and down in revs?
AETD
Can anyone tell me what is the problem when the engine runs like this.
(my neighbours murray with 12Hp B&S)
with lever low the enige runs smooth.
with lever high the revs starts to go up and down.
i allready cleaned the carb
te right arm (governor?) is pushing the throttle up and down.
youtube vid.
http://www.youtube.com/watch?v=aaJssLyJMJw&feature=plcp
TT
Have you tried adjusting the main jet needle? It's the one that points straight down out of the bottom of the float bowl nut.
AETD
Jep i did, when i turn that open (now it is about 1 and 1/2 turn open) from 2 it starts shooting flames true the exhaust when rev up and back to idle. ;-)
spark plug have the right color so i think mixture is good.
when i hold the arm i can feel it pushing.when u put a small screwdriver inbitween, it runs normal... I'm starthing to think the governor have a problem.
no wthe engine have not enough revs/power to mow.
riding is just possible but it's like riding a camel. (lol)
Rooster
Governor spring needs replaced is a common cause of that.
AETD
New governor spring did the job.
thanks
  • Similar Content
    • Gcw804
      By Gcw804
      I have a WH 300 series with a Kohler Magnum 10 engine and I cannot for the life of me figure out how to get the choke cable and linkage set so it will work. The numbers on the engine label  are worn off the, so I cannot give anyone that information. Does anyone have a picture or can you head me in the right direction.
      My arm for the linkage assembly is set at 3 o'clock and 9 o'clock if that helps. There seems to be several different linkage rods for this engine.
      Thanks
      Gary Williams
    • cJ_3D
      By cJ_3D
      Hey all!
      Replacing the drive belt on my 252-h. Anyone know the torque specification for the center screw when I put this pto clutch back on? I know it was on there tight it took a minute for the impact to break it loose. Thanks!
      CJ
    • bkarp@roadrunner.com
      By bkarp@roadrunner.com
      my magnum 12 kohler all of a sudden is blowing oil out of the carb. if rings are bad should oil be blowing out of the muffler.thanks for any help brent
    • Tinman1962
      By Tinman1962
      Recently got hold of a 656 it's has a "newer" 61/2 Briggs on it I don't believe that's right any ideas about that
    • Little Red Horse
      By Little Red Horse
      Hey all. I have a Electro 12 with a factory belly blade. It runs* and drives. I had used it to grade my driveway the last 6 yrs. Having moved I'm looking at my options on storing it or selling it. Frankly I have no idea what it is worth. I watched "ISaveTractors" video on 5 things to do with a new to you wheel horse/12hp kohler. (When i got it 6yrs ago) And went thru and did the adjustments and replaced the parts mentioned. It has been a good strong tractor for me until around July of this year. (2023)
      *Around July it started dying after running 20-30min. I replaced the carb (Chinese Amazon purchase) with one from isavetractors web site. That seemed to help it idle smoother(the old carbs jets wouldnt adjust), but it still dies at around 20-30min.
      So I've got 2 questions.
      1. What is it worth? (As-Is) and
      2. What do I need to do to fix it?
      Thanks yall!
