vikingex30 0 #1 Posted May 6, 2012 hello! i have a 10hp wheel horse with 3 gear + R. it says uni drive pat. no. 2988185. i need new seals and bearings and one of the gear fork has broken. it was stuck and broke when i took it appart. how to find new ones? Share this post Link to post Share on other sites
vikingex30 0 #2 Posted May 6, 2012 my english is bad so hope u undestand what i meant.. Share this post Link to post Share on other sites
Anglo Traction 759 #3 Posted May 6, 2012 Velkommen VIKINGEX30 Lars will be a Happy man when he sees another Member on here!. Can you give us the Model Number of your Tractor ?. Your written English is good and I'm sure we can help solve your problem with parts. Share this post Link to post Share on other sites
Lars 526 #4 Posted May 6, 2012 Hey velkommen til here u can get the help u need.. Yes Richard it is fun to se one more member from .. So i dont feel so alone here Share this post Link to post Share on other sites
wheeledhorseman 573 #5 Posted May 6, 2012 Hei og Velkommen til Another new Euro member! It's always good to post a photo to help with identification (really it's because we like looking at other peoples tractors) BTW your english is very good! Andy Share this post Link to post Share on other sites
racinfool40 202 #6 Posted May 6, 2012 Welcome..And I have to say pics are worth a thousand words..I should have everything you need..seals bearings and shift forks..post some pics if ya can and let me know what all you need.. Shipping won't be a problem but it's kinda pricey..I have shipped many a parts to Knursen..Lars in Norway. Mike Share this post Link to post Share on other sites
AMC RULES 36,963 #7 Posted May 7, 2012 :norway: :norway: Share this post Link to post Share on other sites
vikingex30 0 #8 Posted May 7, 2012 thanks for the varm welcome trying to upload some pics but they are to big modell no is 71-10K4 out try taking some pics with the phone.. Share this post Link to post Share on other sites
vikingex30 0 #10 Posted May 7, 2012 the tranny was full off water when i got it and 2-3 gear was stuck. Share this post Link to post Share on other sites
racinfool40 202 #11 Posted May 7, 2012 Ouch!!! I can say That's the 1st time I have seen that happen to a shifter fork....I have a few of them also.looks like your gonna need a 3/4 input shaft sel a 5/8 brake shaft seal and 2-1" axle seals..Hows the bearings look??? I have all the seals and shifter forks and I do Have some 1" axle needle bearings also..Let us know what all you think your gonna need. As far aa everything else give it a good cleaning and we caqn go from there. mike Share this post Link to post Share on other sites
vikingex30 0 #12 Posted May 7, 2012 some of the bearings are stuck so i shuld change all off them. sounds great! :) Share this post Link to post Share on other sites
Coadster32 793 #13 Posted May 7, 2012 Perhaps I'm mistaken, but I'm pretty sure the brake shaft is the same seal as the axle seals. (Might want to check b-4 ordering.) Good luck and welcome to RS. Share this post Link to post Share on other sites
vikingex30 0 #14 Posted May 7, 2012 i will. thanks :) Share this post Link to post Share on other sites
racinfool40 202 #15 Posted May 7, 2012 Yes. it depends on where your brake hub is mounted, I couldn't tell from your pics, If the brakes hud is mounted close to the axle tube then you will need another 1" seal..My Mistake I should have stated that before.. But in any case I do have them also.. MIKE Share this post Link to post Share on other sites
vikingex30 0 #16 Posted May 7, 2012 it is on the left side in front of the axle. you can se it on the pics. on the pics with the diff to the right and the gears to the left it is on the outside off the gears. Share this post Link to post Share on other sites
Lars 526 #17 Posted May 7, 2012 Auch this is not looking good.. do u have a pict of the tractor too? Share this post Link to post Share on other sites
Anglo Traction 759 #18 Posted May 8, 2012 Look's like the Tranny could be a 4 speed Unidrive with Brake Shaft in similar position as an 8 speed. I think it could be a 3/4"dia (19mm) Seal/needle Bearing on the Brake Shaft? . Vernier Calipers anyone !. Good of you to offer your services Mike . Share this post Link to post Share on other sites
can whlvr 991 #19 Posted May 8, 2012 i think you are wise to replace all the bearings,maybe the big set ,the 1533 bearing might be salvageable,but do the rest while you are in there Share this post Link to post Share on other sites
roger 0 #20 Posted June 12, 2013 I have a uni drive pat. number 2988185 for sale. 80.00 call 1 330-626-3131 Share this post Link to post Share on other sites
