AristosIV
Solenoid
AristosIV
I have a Wheel Horse w/11 HP engine. It won't turn over, but if I jump from the battery negative post, and the positive to the starter, it turns over. I know I should check the solenoid, but I cannot locate it. It's a stupid question, but I am unable to locate it.
Kelly
What model tractor? that will help alot.
Don1977
I have a 10 hp vertical shaft Briggs it doesn't have any thing that looks like a regular solenoid. It's easy to hand start and I don't keep a battery on the mower as I don't use it much. It does have a small plastic box with three wires coming from it looks more like a relay.
redhorse100
if it is a b-111 the solenoid is under the gas tank behind the steering post. you have to take the battery out to see it
Kelly
I guess follow the pos batt cable that should lead you right to it.
AristosIV
It's B115 Automatic. I really should have told everyone
