AristosIV 0 #1 Posted May 5, 2012 I have a Wheel Horse w/11 HP engine. It won't turn over, but if I jump from the battery negative post, and the positive to the starter, it turns over. I know I should check the solenoid, but I cannot locate it. It's a stupid question, but I am unable to locate it. Share this post Link to post Share on other sites
Kelly 1,038 #2 Posted May 5, 2012 What model tractor? that will help alot. Share this post Link to post Share on other sites
Don1977 606 #3 Posted May 5, 2012 I have a 10 hp vertical shaft Briggs it doesn't have any thing that looks like a regular solenoid. It's easy to hand start and I don't keep a battery on the mower as I don't use it much. It does have a small plastic box with three wires coming from it looks more like a relay. Share this post Link to post Share on other sites
redhorse100 4 #4 Posted May 5, 2012 I have a Wheel Horse w/11 HP engine. It won't turn over, but if I jump from the battery negative post, and the positive to the starter, it turns over. I know I should check the solenoid, but I cannot locate it. It's a stupid question, but I am unable to locate it. if it is a b-111 the solenoid is under the gas tank behind the steering post. you have to take the battery out to see it Share this post Link to post Share on other sites
Kelly 1,038 #5 Posted May 5, 2012 I guess follow the pos batt cable that should lead you right to it. Share this post Link to post Share on other sites
AristosIV 0 #6 Posted May 6, 2012 It's B115 Automatic. I really should have told everyone Share this post Link to post Share on other sites
