VinsRJ
RJ35 Rear Hub Set Up / Request Assistance
VinsRJ
I was wondering if a member would have any pics of the internals of their RJ35 rear hubs. I have a 57 RJ35 which has the wire spring which raps around the axel/paw set-up and untimantly controls the paw engagement. For some reason I have drawn a blank on how this goes back together and cannot figure out how this works correctly. I have iffy engagement and its because the spring keeps popping out of position (I obviously have it set up wrong). All of the parts are in good shape, no wear and full teeth in the hub.
I appreciate any assistance!
stevebo
Vince,
If no other members help you out I can pull the other 57 out of the shed and pull the hub and take pics for you.
