racinfool40 203 #1 Posted May 3, 2012 Ok .Myself and Lars (Knursen-The Norweign HillBilly)..LOL...Have been trying to find out what is going on with some drive pulleys for the Raiders..I have posted 2 pic's of the said pulley's..Both have 7492 stamped on one fin and Both have 100425 stamped on the other fin..But one is for 5/8 input shaft on raider 6-speeds-5060 trans.The other has a 3/4 shaft opening for??????? is the question.On his Raider which is in Norway has a 4-speed 5084 trans..Is this the case with the 5084,s here in the States????? Every manual and parts look up I have found, If you try to order this pulley you will get one with a 5/8 input shaft opening. Myself and Lars have searched and searched for this pulley with the 3/4 shaft opening and did find the one I have on E-bay..But the owner had no idea what it came on. So any insite would be great on these mystery drive pulleys..Thanks Mike Share this post Link to post Share on other sites
Lars 526 #2 Posted May 3, 2012 Hey billyhill what is that thing sticks out in the bottom of the pict??????????? yep we realy need to find it out.. :eusa-think: 1 Share this post Link to post Share on other sites
Kelly 1,033 #3 Posted May 3, 2012 Well you got me thinking, and first thought was the newer 4 speed tractors used the larger drive pulley on the engine so they would need the larger pulley on the trans to keep the ratio correct, they didn't make many 4 speed tractors with the large engine pulley, and made non after 75, so I went to look at a few I have here well they are packed in like cord wood so it was hard to read a tape very good, should have taken calipers with me, but it looks like my B-80 4 speed has that pulley with a 3/4" hole, the 8 speed next to it looks to be 5/8" my guess is any newer 4 speed should have that pulley, they just bored it out for that application. Share this post Link to post Share on other sites
TT-(Moderator) 1,162 #4 Posted May 3, 2012 7492 is the 5/8" bore pulley 100425 is the same pulley, but with the 3/4" bore ~ used on the 4 speed models with the brake drum mounted to the countershaft. Tranz numbers appear to be 5080, 5084, & 5085 only, Share this post Link to post Share on other sites
racinfool40 203 #5 Posted May 3, 2012 Thanks Fellas, Makes a little more sense now..So if anyone out there needs these pulley make sure you get the right one for your input shaft.. Mike. Share this post Link to post Share on other sites
AMC RULES 37,225 #6 Posted May 3, 2012 Hey billyhill what is that thing sticks out in the bottom of the pict??????????? yep we realy need to find it out.. :eusa-think: Find out about what? The pulley...or the thing sticking out? :ROTF: Share this post Link to post Share on other sites
Lars 526 #7 Posted May 4, 2012 Hey billyhill what is that thing sticks out in the bottom of the pict??????????? yep we realy need to find it out.. :eusa-think: Find out about what? The pulley...or the thing sticking out? :eusa-whistle: well.. both :eusa-whistle: Share this post Link to post Share on other sites
