dobeleo 7 #1 Posted April 26, 2012 I found a Model No. 79370 Tiller for sale.. I have a 1986 312-A. I looked at an implement chart here and I think it will fit on my beast. Could someone verify that this will fit and also I am looking for a manual so I can see if the tiller has all the parts. Thanks all for your help! Dan Shorewood, Illinois Share this post Link to post Share on other sites
dobeleo 7 #2 Posted April 29, 2012 Just bumping this to the top I appreciate all your input! Dan Shorewood, Illinois Share this post Link to post Share on other sites
zieg72 209 #3 Posted April 29, 2012 Yes this should fit your tractor. I have seen this on Craigslist, make sure it is all there. You have to install a lift cable if your tractor doesn't have one. https://lookup3.toro.com/partdex/ is the place to go, type in the model # and you will see what it is and what should be all there and also what is needed. Share this post Link to post Share on other sites
dobeleo 7 #4 Posted April 29, 2012 Thanks Zieg72, I downloaded the manuals from the Toro website. Dan Share this post Link to post Share on other sites
Road-Track 39 #5 Posted May 2, 2012 make sure you also get the rear clamps that bolt on the axle if you don't already have them :eusa-think: Share this post Link to post Share on other sites
oneroadkingman 53 #6 Posted May 2, 2012 that funny i found one also picking up sat.?? what are tillers worth?? Share this post Link to post Share on other sites
dobeleo 7 #7 Posted May 4, 2012 I emailed him, he does not have the rear clamps that go around the axle or the cable. Are they hard to find? Share this post Link to post Share on other sites
312Hydro 474 #8 Posted May 5, 2012 I emailed him, he does not have the rear clamps that go around the axle or the cable. Are they hard to find? If you have a snow plow then you already have that rear axle bracket. You can make the cable if you can't find one. Tractor Supply has cable and clamps . Does your tractor have the rock shaft (assembly lever, part # 5 https://lookup3.toro.com/partdex/ rear axle mount hitch 110044 ) above the axle? Not a must have as I've seen other members just run the cable to the front rock shaft. There is a helper spring (4629) that makes it easier to pick up. I still have to make the mid hitch idler assembly as it and belt were missing when I bought mine. I also made the assembly lever as my 312H didn't have it either. Share this post Link to post Share on other sites
Kevinfxst 3 #9 Posted May 24, 2022 I have a 70's C-120 and a 73' auto will this 79370 tiller mount to these tractors ? I see on the toro web site there is a mid mount idler assembly do I need that also for my two tractors to make it work ? thanks ahead of time for any helpful information Share this post Link to post Share on other sites
