gwgdog66 23 #1 Posted April 21, 2012 I'm rebuilding my spindles on this mower deck, and lost the pulley woodruff keys some where. The PN# is Hard Hi Pro Key [937222]. Does anyone know the size of the woodruff key? The mower shop is closed and I think I can get the key at Ace hardware. Thanks Share this post Link to post Share on other sites
bowtiebutler956 650 #2 Posted April 21, 2012 Hey Gary. The hardware would probably have it, but I know my local Orielly's here has a good selection of woodruff keys. So if Ace doesn't have it, give them a try. Matt :flags-texas: Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,603 #3 Posted April 22, 2012 Product service bulletin 429 tells us to leave the key out and replace the locknut with a lock washer and free running nut if the spindles are greaseable. Just make sure the pulley is free to spin on the shaft before the nut and washer are installed. Good spot for some Neverseize. The direction of rotation keeps the nut tight and this setup is the same as the most recent spindles. Torque 50-90 lbs. Garry Share this post Link to post Share on other sites
gwgdog66 23 #4 Posted April 22, 2012 Product service bulletin 429 tells us to leave the key out and replace the locknut with a lock washer and free running nut if the spindles are greaseable. Just make sure the pulley is free to spin on the shaft before the nut and washer are installed. Good spot for some Neverseize. The direction of rotation keeps the nut tight and this setup is the same as the most recent spindles. Torque 50-90 lbs. Garry I'll keep that in mind for the next time. Share this post Link to post Share on other sites
