tarcoleo
Why Do I Wheel Horse Around
tarcoleo
Two acres of lawn around my place are mowed weekly or more often. This chore, over the years, has transitioned to a hobby where the restoration, optimization and the use of two classic “C†Wheel Horse units have become pleasure. Work isn't work if you have pride in it, especially if one can enjoy the use of the right tools. Anyway, grass cutting, acre upon acre, round and round, over a couple hours, is transfixing, “a Zen experience that allows one to see into one's own true nature, and thus attain Buddhahood or enlightenment.†Well I guess.
AMC RULES
To attain :wh: enlightenment, must you always mow in the same direction? :scratchead:
6wheeler
Wait, What? I was going to plow and it started raining. You lost me somewhere, I'm sorry. I was daydreaming. I'm sorry. What was that about cutting grass? :teasing-poke::teasing-neener: . When you are able to obtain this pebble from my hand. You too grasschopper, WILL become most enlightened....
Pollack Pete
Depends if you're north or south of the equator.Just like the whirlpool in a toilet. :)
1maidenfan
:ph34r::violence-blades: :ROTF:
bowtiebutler956
I don't know about receiving enlightenment from mowing, :ROTF: but I do have alot of fun! :woohoo:
Matt :flags-texas:
tarcoleo
Yes, in ever smaller and smaller circles 'til one obtains Nirvana. :)
AMC RULES
OK then, in Nirvana...does a :wh: mowing concentric circles with no one around to hear it, make a sound? :teasing-poke:
Philnc
Tried enlightenment but got tired of all them salads...back on burger diet.....................
SAM58
If I want enlighten, I just turn on the lights... :eek:
c161rat
Grasschopper!!!!!!!!!! LOL
tunahead72
Q: Why Do I Wheel Horse Around?
A: Because you can!
  • Similar Content
    • Deer hunter
      By Deer hunter
      Does anyone know where I could find a complete engine rebuild kit from for the k-19 ? I absolutely love my c-195 and have had it for years. But the motor let go last fall and I want to rebuild it or upgrade the motor, any suggestions?
    • BrianStasC-101
      By BrianStasC-101
    • HumbleHans
      By HumbleHans
      Operator manual 810343R1
      Wiring
      34 pages 17.5MB
      Wiring Colored
      1 page 228KB
      1984 C-105 8-Speed model 11-10K802
      1984 C-125 8-Speed model 11-12K802
      1984 C-145 Automatic model 11-14KE01 - Some used alternate inner axle bearing See PSB #369
      1984 C-165 8-Speed model 11-16K801
      1984 C-175 Twin Automatic model 11-17KE01 - Some used alternate inner axle bearing See PSB #369
      1984 C-195 Twin Automatic model 01-19KE02
    • t_furl43
      By t_furl43
      1979 c-101 nice project tractor just needs a few odds and ends, steering wheel, coil, carburetor bowl, the wiring was redone by previous owner....all 4 tires are good and hold air it goes into all gears no problem, transmission fluid has been changed, 10hp Kohler, message me or call or txt with any questions, it does run and runs well,  it’s been kept inside since I’ve had it, I would also trade for a mid mount grader blade thanks
      92DB561C-FF95-4868-A52B-5725D4D3B9DE.mp4
    • RJ Hamner
      By RJ Hamner
      Will the plow I am using on my C121 and C160 work on a 876?
      or is the plow frame different?
      Thanks
      Bob
