mrc 1,122 #1 Posted April 12, 2012 hi guys, i have a tiller that is leaking gear oil from the tiller gearbox. it is leaking from the left side stub shaft. (if you are behind the tractor looking at the tiller). i assume there is an oil seal surrounding the stub shaft in the gear box housing. do any of you know the seal dimensions or a part number??? preferably a napa, carquest crossover number??? thank you in advance for your help. mike in mass. Share this post Link to post Share on other sites
can whlvr 994 #2 Posted April 12, 2012 i just did mine yesterday on a tiller from 1975,i took the seal to the bearing store and they hooked me up with a timken seal thats 3/4 inside,1 inch outside and about an 1/8 thick,the timken number is 312518 .750x1.00x0.125,sorry dont know if you can cross to napa or carquest,maybe they can cross referance Share this post Link to post Share on other sites
Wheel-N-It 2,978 #3 Posted April 13, 2012 Hey guys, I need that number too. The left side seal on my year model 1991 tiller is leaking. I have to keep it raised up in the air to keep the gear oil from running out. Mike, remember to put 90w/140w back in your tiller unless you know for sure yours requires something different. My tiller gearbox is nice and quiet with Lucas gear oil in it. Van Share this post Link to post Share on other sites
can whlvr 994 #4 Posted April 13, 2012 thats a very common sized bearing,if noone has the other numbers im sure they can cross referance the timken number,i recommend you guys go to a bearing shop,they will have these on the shelf,i paid 8 bucks and they were better than the toro seal,which only lasted one year Share this post Link to post Share on other sites
Wheel-N-It 2,978 #5 Posted April 13, 2012 Thank you CW ! Share this post Link to post Share on other sites
gwgdog66 23 #6 Posted April 13, 2012 Looks like a Napa 7408 http://www.napaonline.com/Catalog/Result.aspx?Ntt=312518&Ntk=Interchange+Number&Nty=1&Dn=0&D=312518&Dk=1&Dp=3&N=0 Share this post Link to post Share on other sites
mrc 1,122 #7 Posted April 13, 2012 hi guys, my tiller is different. the decal says toro/wh so i'm assuming its newer??? any way shaft size is 1.250 hole in gearbox is 1.500 for reference national seal # 343186. i will pick them up tomorrow and hopefully solve the leak. mike in mass. Share this post Link to post Share on other sites
pfrederi 21,306 #8 Posted April 13, 2012 That should be the correct seal for a 77-36TL01 tiller. (at least it is the one I used and is listed in teh bearing reference pinned in the tranny section. It is WH # 103118 CR/SKF 12330 Giving the model number of the tiller helps us give you better help. Share this post Link to post Share on other sites
mrc 1,122 #9 Posted April 14, 2012 hi pfrederi, the tiller has no I.D. tag on it. wish it did. mike in mass. Share this post Link to post Share on other sites
mrc 1,122 #10 Posted April 29, 2012 hi guys bought seals at napa. box says napa/skf #12330. seal measures I.D. @ 1.250 O.D. @1.505 definitetely stopped the leak . regards mike in mass. Share this post Link to post Share on other sites
Michaelzz28 22 #11 Posted July 8, 2017 On 4/12/2012 at 11:07 PM, Wheel-N-It said: Hey guys, I need that number too. The left side seal on my year model 1991 tiller is leaking. I have to keep it raised up in the air to keep the gear oil from running out. Mike, remember to put 90w/140w back in your tiller unless you know for sure yours requires something different. My tiller gearbox is nice and quiet with Lucas gear oil in it. Van Your a betting man than me I can not hear anything when the tractor is running it I just use the cheap gear oil Share this post Link to post Share on other sites
