Hodge71
d seires mower belt tension
Hodge71
Can anyone explain to me how the deck drive belt on a D belly mower gets tensioned? I'm having a tough time understanding how this is going to work with a mule drive thats not adjustable. C's 3,4,5, series tension is adjusted by the mule drive up front...so how does the D work?
Any help will be appreciated :thanks:
1maidenfan
Was looking at the adjuster on my 18 auto and my D160 and was wondering the same thing. :confusion-confused: Guess its time to get my manual out and find out. :huhs:
coldone
made this vid. It aint too good but maybe it will help.
Trouty56
Yeah...the whole deck moves back. Nice video!!
1maidenfan
That was actually a great video of how to adjust belt tension on the D series deck.
Thanks.
:notworthy::text-goodpost:
Did you tag that under D series? Could ya?
:teasing-poke:
:text-thankyouyellow:
coldone
Made it public and corrected the spelling and tagged it on youtube as "D200 belt tension".
Hodge71
Thats awesome Coldone. I actually have that bracket assembly under my tractor. I didnt know what it was for and was going to take it off actually. I'm just happy that for once there isnt something I have to buy for this damn thing!!!
  • Similar Content
    • tractorboy79
      By tractorboy79
    • BuffaloD200
      By BuffaloD200
      '74 D-180
      My friction disc in gone on my clutch.  I saw the old post about making a new friction disc, so I'm not concerned about that.
      I managed to remove the front clutch plate and double v-belt pulley.  But I can't separate the two.  When I took the assembly off the spiraloc washer popped off on its own.  I HAVE READ THE MANUALS.
      So I should be able to just remove the pulley from the front clutch and continue with step 4.  The v-belt pulley is loose as all hell and flops around like a dead fish.  It seems to be hung up on a ring or bearing race.
      So my thoughts are grab a BFH or sparky the blue tip wrench.
      Is there an unpublished step 3.5, or some trick?
    • BuffaloD200
      By BuffaloD200
      Hey all,
      My '74 D180 has a lot of trouble pushing snow.  Weighted tires, but nothing else at this time.  I've found it gets stuck frequently and only one wheel spins.  Do these tractors not have a limited slip/locker arrangement?  How does everyone manage with the infamous one wheel peel?
    • BuffaloD200
      By BuffaloD200
      Hey all, I need to install a drive belt on my 75 D180 for my snowblower.  I've looked through a bunch of D-series owner's manuals, and none seem to mention replacement procedure.  The PTO pulley is fixed, save for engaging the PTO and there is minimal movement at the snowthrower pulley. There's no idler or tensioner as far as I can tell.  Do I have to remove the PTO pulley?  That seems to be a required service item.
      Same question for my 80 D200 as well really.
      Using the recommended 4L490W belt.
      Thanks
    • ihatephones
      By ihatephones
      I got a D-180 for $250, and the governor is messed up, the points won't open or close, and I took it apart and was being stupid and messed some stuff up in there, and now I need a new one.
      Where can I get one that's not on eBay for $200?
      I also forgot to say it was a Kohler K482, and I'll throw some pictures of the tractor in as a treat.
