krazy_horse 59 #1 Posted April 9, 2012 My 856 was not braking to well so this a.m. I was going to adjust the band when I found freash 90wt. trans oil on the brake band and pully. It looks to be seeping between the shaft where it comes out of the tranny. I have never been inside one of these trannys but it looks like the seal will be an inside job. Is this correct? What parts will I need to have on hand? I am going to The Wheel Horse Show in June so I will leave her parked till then. Regards, Jim O yes its a 3 speed Share this post Link to post Share on other sites
WH854 45 #2 Posted April 9, 2012 My 856 was not braking to well so this a.m. I was going to adjust the band when I found freash 90wt. trans oil on the brake band and pully. It looks to be seeping between the shaft where it comes out of the tranny. I have never been inside one of these trannys but it looks like the seal will be an inside job. Is this correct? What parts will I need to have on hand? I am going to The Wheel Horse Show in June so I will leave her parked till then. Regards, Jim O yes its a 3 speed It's been done from the outside you have to take the break drum off Chas Share this post Link to post Share on other sites
WH854 45 #3 Posted April 9, 2012 Seals for it 3/4 " Brake Shaft 100441 C/R 7410 1" Axle -Old Brake Shaft 1232 C/R 9815 5/8 (.625) Input Shaft 100442 C/R 6105 1-1/8" Axle 100443 C/R 11050 Share this post Link to post Share on other sites
krazy_horse 59 #4 Posted April 9, 2012 You guys made my day. Thanks so much for the info. and part numbers. Thanks again. Regards, Jim Share this post Link to post Share on other sites
krazy_horse 59 #5 Posted April 25, 2012 Supporter listed the number of a one inch old brake shaft seal as #1232 cr 9615. The local NAP say they cannot find this number. Any one have a cross refferance number? The tractor is a 856 with a three speed. Thanks jim Share this post Link to post Share on other sites
racinfool40 203 #6 Posted April 25, 2012 The new Toro # is 100863 which is the same for the 1" axle seal and can be used for both the 1" axle and the 1" brake shaft. MIKE Share this post Link to post Share on other sites
pfrederi 18,719 #7 Posted April 25, 2012 Supporter listed the number of a one inch old brake shaft seal as #1232 cr 9615. The local NAP say they cannot find this number. Any one have a cross refferance number? The tractor is a 856 with a three speed. Thanks jim Maybe because the # is 9815 not 9615 as you typed above Share this post Link to post Share on other sites
krazy_horse 59 #8 Posted April 25, 2012 Thanks Mike, I called Napa back and gave them the number you gave and the seal will be here in a.m. Yes, I am bad about hitting the wrong key and transposing numbers but I"m and old guy!! Share this post Link to post Share on other sites
