Shuboxlover 488 #1 Posted April 9, 2012 I picked this tractor up (1994 314 Auto) a couple weeks ago and while I was running it through its' paces checking eveything out, while I was mowing at WOT it would hesitate for a split second every now and again. It was just a real quick hiccup. It does it fairly consisitantly, doesn't seems to matter if the engine is warm or not. It's a Magnum, so there are no points to check/adjust. Where would you start. Do you think it's as simple as a carb cleaning, or should I look at something else? Thanks Share this post Link to post Share on other sites
gwgdog66 23 #2 Posted April 9, 2012 I picked this tractor up (1994 314 Auto) a couple weeks ago and while I was running it through its' paces checking eveything out, while I was mowing at WOT it would hesitate for a split second every now and again. It was just a real quick hiccup. It does it fairly consisitantly, doesn't seems to matter if the engine is warm or not. It's a Magnum, so there are no points to check/adjust. Where would you start. Do you think it's as simple as a carb cleaning, or should I look at something else? Thanks Probably some varnish in one of the passages. I picked up a 312-8 a while back with low hours, and wound up replacing the line; filter and cleaning the carb real good to get it to smooth out. Share this post Link to post Share on other sites
can whlvr 994 #3 Posted April 9, 2012 yep i agree its something in the carb or float bowl Share this post Link to post Share on other sites
varosd 1,185 #4 Posted April 9, 2012 consider gunk in the gas tank. the in tank filter will sometimes get clogged and unclogged as gas swishes back and forth. I know thehard way! real easy to drop the tank,clean it out and replace the fuel lines and filter at the same time. Share this post Link to post Share on other sites
Shuboxlover 488 #5 Posted April 9, 2012 GREAT sugestions guys....gonna clean the tank out and clean the carb!!! I'll keep you updated!!!! Thanks Share this post Link to post Share on other sites
