Cessna 1 #1 Posted April 8, 2012 Yesterday my truck quit and I could not get back into my driveway. I got the WH GT 1142 and a tow cable and started to move the F-250. Unfortunately the tow strap came loose and the hit the bottom of my fuel tank (plastic) and the gas leaked out. Can the plastic be repaired? If so, how? Share this post Link to post Share on other sites
rmaynard 17,642 #2 Posted April 8, 2012 I have not found a glue or solvent that will mend polyethylene. The best thing to do is find a good used tank and replace it. I currently have one that I just listed on eBay. Item #320884768385. If you need it in a hurry, I can end the auction early. Share this post Link to post Share on other sites
oldredrider 2,554 #3 Posted April 8, 2012 Used fuel tanks are fairly cheap and plentiful. It would be easier to just replace it than try and repair it. Share this post Link to post Share on other sites
AMC RULES 37,260 #4 Posted April 8, 2012 Yep find another, not worth the aggro bro...but then again...if you were determined to try, and get creative...this stuff just might give you the best results. :dunno: Share this post Link to post Share on other sites
squonk 48,319 #5 Posted April 8, 2012 Did you end your auction early Bob? I didn't see it listed I have the same tank on there but with a sending unit for a 520 Share this post Link to post Share on other sites
rmaynard 17,642 #6 Posted April 9, 2012 Did you end your auction early Bob? I didn't see it listed I have the same tank on there but with a sending unit for a 520 It's still there. Share this post Link to post Share on other sites
Cessna 1 #7 Posted April 11, 2012 Local WH dealer want $182 for the tank. Share this post Link to post Share on other sites
jusjeepn 59 #8 Posted April 11, 2012 http://www.harborfre...=plastic+welder You can probably buy a tank cheaper but this can be used over again and you could actually recoup your initial investment! Share this post Link to post Share on other sites
Wheel-N-It 2,978 #9 Posted April 11, 2012 I have repaired several cracked truck batteries by using a big electric soldering iron and melting plastic strips i cut out of a gallon milk jug into the crack and melting the cracked area of the battery to fuse it all together. I have probably done this to four or five batteries and it worked every time. I would not hesitate to try this on a WH fuel tank. Share this post Link to post Share on other sites
