1054josh
Round hood help please
1054josh
Hi all, im in a bit of a pickle here. My problem is that i have a 702 and the hood i have needs some repair on the front bottom edge where it mounts to the frame. I want this restore to be as close to original as possible and would like some input on what i should do. Is the mount that i have original or has someone replaced it? does anyone have a good pick of an original mount? Am i taking hood to far and should i just leave how is? Here are some pics of the problem area. Thanks in advance this is such a vast information place i love it,u all are awesome.post-6518-0-52156800-1333661505.jpgpost-6518-0-50709300-1333661506.jpgpost-6518-0-01105900-1333661507.jpgpost-6518-0-55498100-1333661507.jpgpost-6518-0-11767800-1333661508.jpg
O and here is how its coming so far rest is being painted hopefully next week
sorekiwi
Thats a fairly typical problem area on a round hood.
There is a pic on how I repaired the one on my Ranger here:
Basically I cut out all the bottom and replaced it with new steel. Cut the bracket off the old metal and welded it to the new patch. Its not hard to do if you take your time and pay attention to keeping everything lined up where it should be. Its all in a hard to see spot so any imperfections arent out in plain view for the world to see.
Jake Kuhn
Tractor is looking really good! Jake
AMC RULES
Looks like it's been repaired before, is that weld material or Bondo in there? :scratchead:
1054josh
Thanks for the link sorekiwi.it helps a little. Thanks jake and its brazing craig.is that what the mount is suppose to look like?
1054josh
Any of u round hood guys got an original hood mount that would care to share a pic? I sure would be thankful
rmaynard
I'm going to dredge this one up again since I have a similar issue with my 701 hood. This is what the bottom of mine looks like.
post-2221-0-38083000-1348573382_thumb.jp
post-2221-0-90768800-1348573400_thumb.jp
post-2221-0-94998700-1348573425_thumb.jp
post-2221-0-23399500-1348573433_thumb.jp
As you can see from the last picture showing the inside, the metal is cracked in the center and at both rivets. This allows the bracket to wobble. Was the bracket attached by pop-rivets from the factory, or is this a repair?
Any idea what the oval hole is for?
My initial thought was to remove the rivets, make a backer plate to go on the inside, and sandwich the cracked hood between the bracket and the backer. Any thoughts?
littleredrider
I'm pretty sure they were tack welded on. Possibly where that center hole it....
rmaynard
You are correct. Closer inspection reveals an old tack weld at the arrows, and probably one where the rivets are now.
post-2221-0-73774700-1348575696_thumb.jp
AMC RULES
Seems at some point over the years, mine has been repaired too. Original spot welds are still visible though.
post-3498-0-25784200-1348588589_thumb.jp
SousaKerry
The oval hole may have been a carrier for a progressive die or an alignment hole for the form die(if it was a one hit die,) but more then likely a stress relief point or even a place for the water to drain out when out in the rain. One thing for sure the Manufacturing Engineer who put it there is probably long gone, and we will never know.
Kelly
They were welded on, I have a few 701 hoods, some repaired, but 2 orig. I think the nose of the hood is from the dies that made the suburban hoods and that hole is how they bolted them to the frame on the mid engine tractors.
rmaynard
I figured that if anyone would know, it would be Kelly. :thumbs:
Kelly
That is a guess on the hole, but it is the same hole as the suburban hoods I've had, and the nose part with out the grille is the same as a suburban.
I'd weld up the cracks, grind it down, drill out the rivet holes a bit, drill out the two holes just off center in the bracket and plug weld them to the hood, that is how I'm going to fix my nice hood that is missing the bracket, after I rob the bracket off a hood someone cut up, the 701 bracket is not the same as the newer ones also, another 701 only item.
TT
You are correct on the hole, Kelly.
As a matter of fact, they are the exact same hood as a 401/551 - except for the rear mounting holes / tank cut-out and the added front bracket.
rmaynard
I'd weld up the cracks, grind it down, drill out the rivet holes a bit, drill out the two holes just off center in the bracket and plug weld them to the hood...
Since my welding skills involve burning holes in sheet metal, I think that I will stick with rivets.
Kelly
You missed one thing TT, the 401/551 gas tank fill hole, is not there....... just pickin on ya. :ychain:
I think at some point over the years here, I seen where someone cut up a ranger hood to fit the alum gas tank tractors, and filled the ranger tank hole also.
TT
Oops.... no gas tank hole either. :hide:
"kpinnc" has this one now, but I did the 551 hood on a 701 a while back:
You bought a nice one, Bob!
There's going to be a bunch of them at Arendtsville by the looks of it.
SousaKerry
Wow I am so jealous of that scrap pile, mine doesn't look half as good or valuable :ychain: :hilarious:
rmaynard
Thanks TT. Are we going to see you and your '61's there next year?
TT
I would like to be there next year. I still have a 701 left - which I'll be sure to bring. :handgestures-thumbup:
woodchuckfarmer
Would that little hole be there to hang them on the paint line ?
rmaynard
I don't think they would have needed a hole that big. This hole is about 3/8" x 3/4".
  • Similar Content
    • Mike in NC
      By Mike in NC
      This happened to jump on my trailer. I am thinking it is a 702. 7 HP Kohler with 62 printed on the serial number sticker. It needs some parts and some work, but engine is loose. Can't beat free! Guy said it was his dads tractor and the last time he remembers it running, his dad drove it. He said his dad passed away 26 years ago. Now I have a 701 and 702!
    • ayeater
      By ayeater
      Hello, I am currently nearing completion of the restoration of my Wheel Horse 702 and I am finding parts that I am missing including a starter belt cover, brake guard, seat, deck height adjuster and possibly a new steering wheel. If anyone can point me in the direction to find them I would greatly appreciate it! Thank you!
    • mhlmeader
      By mhlmeader
      Hi folks, long story, but here goes.  My dad got this or at least part of this tractor about 30 years ago, I vaguely remember going with him and helping heft it into the back of a pickup truck.  He ended up blending two tractors together for some reason, I dont know why.  He's used it in his small garden, pulling trailers and such.
        Fast forward, he's 72 now, I'm turning 48 soon.  So, anywho, he tells me his tractor is locked up, wont shift!!! Rutt row!!! But it is at least in neutral.   I didn't have alot of time to mess with it, not that I wouldnt have, so he finds a place in south bend( an old wheelhorse dealership) that will work  on  it.  We load it up, get there, guys come out to look at it, and guy ask if that's a hydrostatic drive!!, oh no, I knew we were in the wrong place, turns out they wont mess with it, too old!  So before it escalates,  I tell my dad, I'll take care of it, I knows some people, dig it!!
        So, on the way home, I says, you have left that tractor outside alot haven't you? Oh no, son, always inside, I didn't believe him.
      So I do some googling, and reading through the forum 9n what to do first, or to try.  First, I drained the oil, but there wasn't any, so I shook the tractor and drained the quart of water outta the tranny.  Then I filled it up with gear oil, started the tractor, let it idle abit, slowly but shirly I could shift through all the gears!!!! Yippy!!!!
       Then I noticed the head gasket appeared to be blown,  was blowing out the side.  Got a new head gasket,  old one wasn't actually blown, but I installed new one anyway, still blowing by.  More googling led me back here to learn to sand the head as best I could, and then more, pluse some spray on copper permatex.  Sealed the gasket!!!! WOO HOO!!
        So next is attaching a fabricated belt restrain on the bottom of the belt guard, I learned I needed that from looking through the forum too, she grinds a little bit when trying to shift.  And I also ordered a new break band today from one of the forum members.
      I actually power washed it today, its seen better days, but starting to look better.  I'm gonna change the tranny fluid again, change the engine oil, and then I'm gonna call it good for now.
        Anyway, just wanted to share about my dad's old horse, and how I been spending my time lately.  Learned alot too!!!
    • CasualObserver
      By CasualObserver
      1962 Wheel Horse sales mini brochure. Original is only 1/4 size of regular paper sheet.
      Full size
      10 pages 1.8MB
    • Tyler71
      By Tyler71
      Hey guys I’m needing to figure out 100% what attach a matic I need to mount a mid mount grader blade to my 702 all I have found is I need a MA-1 speed hitch but what years do I look for or does anyone have pictures
