Marv 845 #1 Posted April 4, 2012 I need a head bolt for the K241. The bolt I need is #7 on the head bolt torque diagram. Marv Share this post Link to post Share on other sites
tunahead72 2,343 #2 Posted April 4, 2012 I'm not an expert, but I believe the exact bolt you need will depend on exactly which head you have on your engine. What's the spec number on your motor? And how long is the bolt you're looking to replace? Share this post Link to post Share on other sites
Kelly 1,028 #3 Posted April 4, 2012 I have used grade 8 bolts from TSC for many tractors, and most of the time all the head bolts are the same size in a engine, so you should be able to pull one and match it up. Share this post Link to post Share on other sites
Duff 206 #4 Posted April 5, 2012 Kelly, I found the one head bolt that holds down the engine hoist thingy on my Magnum 12's is a little longer than the rest..... I use grade 8 bolts from the local hardware, too. Duff :thumbs: Share this post Link to post Share on other sites
Marv 845 #5 Posted April 6, 2012 Thanks everybody. Grade 8 sounds fine. I did get the size and length from the Kohler parts site. Marvin Share this post Link to post Share on other sites
