JamesBe1
D-180 Exhaust
JamesBe1
Hi Guys. I know this topic has been covered at length for some engines, but I would like to tap into the collective wisdom for my own situation.
I have a couple of D-180's, with Kohler K482's. I am going to swap the engine from the one with the good engine/terrible frame, to the one with the bad engine/good frame.
The problem is that the good engine has trashed mufflers. I am going to have to rig up a new muffler system, but I need to get the old ones off of there. The D-180 exhaust system has flanges that bolt onto the block into which the exhaust nipples are threaded. In another thread, I recounted breaking the engine block using the 'compress the nipple with a chisel method'. Needless to say, I don't want to go near that method again since I don't want to destroy this good engine.
Does anyone have any good tips/tricks/hints/advice for removing the exhaust nipple?
Any help would be appreciated.
Thanx,
James
Sparky
Take a hack-saw blade or use a saw-zall and put the blade inside the nipple and cut a groove in it right to the threads in the block. I did one with two cuts, one on each side wall and it practically fell right out. It only took one small tap and not a big whack. No chisel either. The threads in the block will be fine and a new nipple will still thread right in.
Mike............
Trouty56
Did you hack saw the old nipple down to the threads in the flange first. I actually used a sawzall (spelling)....cut it at 2 places.
Whoops.....2 late!!!
Sparky
Great minds think alike Bob!!
Mike...........
JamesBe1
Gentlemen, I am impressed. And grateful for your input. That is an excellent idea. I never thought of that, but now that you explain it, it makes perfect sense.
I am going to start taking the engine off the tractor tomorrow and put it on a bench to clean it up thoroughly before I install it on the other tractor. It should be a day or two before I get to the sawing part. I'll be using a jigsaw as I don't have a sawsall. If that doesn't cut the mustard (in this case rusty mustard), I'll have to do it by hand. I've been meaning to pick up a sawsall, but never got around to it.
I will let you guys know how it goes. I'll try to remember to take pictures.
James
Trouty56
Mike...........
Mike, I probably picked that technique from one of your posts (I didn't come up with it on my own) so i learned from the best!!
James
James, the exhaust nipple I cut out of a 60's motor was so rusted that it appeared to be part of the block. This will work!! Saw off the nipple so there is a little bit sticking out for you to tap a little with a punch if needed to break it out. I really think it is documented on here with pics somewhere. Don't hurry and take pics. No worries!!
JamesBe1
Ok, got my exhaust off this afternoon. Not too bad at all. I didn't have a sawzall, but I had a jig saw with a metal cutting blade. Good enough.
Here's a pic of the engine before I started:
I cut the first exhaust off with a hack saw:
I cut three slots into the nipple and used a hammer and chisel to collapse one of the segments inside the port. I cut it deep enough so that the segment pretty much fell away from the other two:
The second segment easily collapsed into the port:
After that, just a few taps with the hammer and chisel, and the last segment came loose. Here is a pic of the nipple posing on top of the flange:
I cut the second exhaust off, but this time, I left a few extra threads sticking out. It was very difficult to get the hacksaw in with enough throw to cut, so I ended up taking the blade off of the frame, and cutting with with just the blade:
Again, I cut three segments into the nipple. This time, there wasn't as much room as on the other side. I could barely get the jig saw in place to cut with. I guess I got a little impatient, and didn't cut as deep as I should have. Still, after gently collapsing it with the hammer and chisel, it collapsed into the port. The segments weren't completely separated, but they were weak enough that it folded in on itself. After I got two of the segments to collapse, the third segment came loose on its own. I was able to turn it with a wrench to take it out.
The whole event took a little over an hour (not counting taking the horse out for grass (sorry, not pictures of that this time)).
All in all, yous guys (as we say in NJ), saved me a lot of effort. I can't thank you enough. Beers on are me.
Trouty56
Nice job James. They were pretty rusted!!
Sparky
Beers on are me.
I know you said alot of other stuff but this is all I heard!! :beer:
Glad to hear you got it done!
Mike................
tech270154
Mike...........
i know this job was attend last year but i was just reading it now .
i am very proud of you Mike,you would be a very good service plumber,because this a technique that that we applied on rusty pipe when
avoiding wrecking   "the good side" i am a retired plumber from number years ;
and congratulation to you James to attend a  such of tricky job like that
i own also a d-180  k-482
yves     from  Quebec Canada
JamesBe1
Thanx Yves.
We're all just learning here.  Sometimes I get to learn new and better ways of doing things, and sometimes I get to share them.  Usually more of the former.
Welcome to Red Square.  Feel free to ask questions, or share any information that you may have.
  • Similar Content
    • Gcw804
      By Gcw804
      I have a WH 300 series with a Kohler Magnum 10 engine and I cannot for the life of me figure out how to get the choke cable and linkage set so it will work. The numbers on the engine label  are worn off the, so I cannot give anyone that information. Does anyone have a picture or can you head me in the right direction.
      My arm for the linkage assembly is set at 3 o'clock and 9 o'clock if that helps. There seems to be several different linkage rods for this engine.
      Thanks
      Gary Williams
    • tractorboy79
      By tractorboy79
    • BuffaloD200
      By BuffaloD200
      '74 D-180
      My friction disc in gone on my clutch.  I saw the old post about making a new friction disc, so I'm not concerned about that.
      I managed to remove the front clutch plate and double v-belt pulley.  But I can't separate the two.  When I took the assembly off the spiraloc washer popped off on its own.  I HAVE READ THE MANUALS.
      So I should be able to just remove the pulley from the front clutch and continue with step 4.  The v-belt pulley is loose as all hell and flops around like a dead fish.  It seems to be hung up on a ring or bearing race.
      So my thoughts are grab a BFH or sparky the blue tip wrench.
      Is there an unpublished step 3.5, or some trick?
    • BuffaloD200
      By BuffaloD200
      Hey all,
      My '74 D180 has a lot of trouble pushing snow.  Weighted tires, but nothing else at this time.  I've found it gets stuck frequently and only one wheel spins.  Do these tractors not have a limited slip/locker arrangement?  How does everyone manage with the infamous one wheel peel?
    • BuffaloD200
      By BuffaloD200
      Hey all, I need to install a drive belt on my 75 D180 for my snowblower.  I've looked through a bunch of D-series owner's manuals, and none seem to mention replacement procedure.  The PTO pulley is fixed, save for engaging the PTO and there is minimal movement at the snowthrower pulley. There's no idler or tensioner as far as I can tell.  Do I have to remove the PTO pulley?  That seems to be a required service item.
      Same question for my 80 D200 as well really.
      Using the recommended 4L490W belt.
      Thanks
