Shawn Harrington
K181 Starter issue? not sure C-85
Shawn Harrington
Hi guys,
Seems to be a great source of experts on this site :) My C-85 won't start, it seems that the starter is getting juice but not fully engaging? can the starter get off alignment? I can hand spin the starter component that engages the engine. There just doesn't seem to be any resistance when I spin the starter motor (forgive me for not knowing the part names). I checked ground wires and wires connection to starter and all are secure. Any ideas on what to look for?
Thanks all,
Shawn in Mass.
Sparky
Try lubing it with grafite. Its a powder and grit/dirt wont stick to it like a liquid lubricant. Never use oil or something along those lines to lube a starter.
Mike............
:WRS:
rmaynard
If the starter motor is spinning correctly, then the problem is in the Bendix. When the starter spins, the Bendix (part with the small gear) is forced out toward the flywheel gear ring by centrifugal force. Dirt, oil, and grime can get inside the Bendix assembly and keep it from moving. I always use nonflammable brake cleaner to cleaned it out. After it is cleaned it should work correctly. There should also be a spring that pushes the Bendix back after the starter is disengaged.
bowtiebutler956
If you can hear the stater run when you turn the key, but the engine is not turning over, then like Maynard said its probably just the bendix needs to be worked back and forth, and some type of dry lube used on it. Can you hear the starter running?
Matt :flags-texas:
Shawn Harrington
Guys,
Thanks for the input. I do hear the starter turning. It just isn't catching the bendix I guess. I'll see if the dry lube will get it going. Thanks guys and I'll let you know.
Best,
Shawn
pfrederi
Not to hijack this thread but some of the older Kohler manuals suggest using a lubricant on the splined shaft.
It was described as a silicone grease Kohler part # 52-357-01. Anyone ever seen it???? It is $3.91 is it just th silicone dielectric grease you can buy at eh auto parts store??
  • Similar Content
    • Gcw804
      By Gcw804
      I have a WH 300 series with a Kohler Magnum 10 engine and I cannot for the life of me figure out how to get the choke cable and linkage set so it will work. The numbers on the engine label  are worn off the, so I cannot give anyone that information. Does anyone have a picture or can you head me in the right direction.
      My arm for the linkage assembly is set at 3 o'clock and 9 o'clock if that helps. There seems to be several different linkage rods for this engine.
      Thanks
      Gary Williams
    • Deer hunter
      By Deer hunter
      Does anyone know where I could find a complete engine rebuild kit from for the k-19 ? I absolutely love my c-195 and have had it for years. But the motor let go last fall and I want to rebuild it or upgrade the motor, any suggestions?
    • cJ_3D
      By cJ_3D
      Hey all!
      Replacing the drive belt on my 252-h. Anyone know the torque specification for the center screw when I put this pto clutch back on? I know it was on there tight it took a minute for the impact to break it loose. Thanks!
      CJ
    • bkarp@roadrunner.com
      By bkarp@roadrunner.com
      my magnum 12 kohler all of a sudden is blowing oil out of the carb. if rings are bad should oil be blowing out of the muffler.thanks for any help brent
    • Tinman1962
      By Tinman1962
      Recently got hold of a 656 it's has a "newer" 61/2 Briggs on it I don't believe that's right any ideas about that
