COMMANDO1 23 #1 Posted March 9, 2012 before i get started tearing into it here is my question, i will be removing a 1972 8 horse briggs vert. and replacing w/a 1980 or so 12 horse. will the old drive pulley go on the newer engine? and will the shaft length be the same? Share this post Link to post Share on other sites
Docwheelhorse 2,992 #2 Posted March 10, 2012 Its completly possible... but all engine manufactures had several different diameter and lengths for the cranks. Only thing you can do is pull the old motor and match it up with the new engine. You may also be able to buy the correct oulley setup to match the new engine. Tony Share this post Link to post Share on other sites
COMMANDO1 23 #3 Posted March 12, 2012 THANKS...CLOSE POST Share this post Link to post Share on other sites
