wheeledhorseman
PTO clutch plate lining
wheeledhorseman
I need to replace the friction lining on the PTO of my C-100.
Can anyone tell me the original thickness of the lining when new?
I'm thinking of just bonding the new lining to the plate with epoxy rather than using rivets - is that ok?
Thanks
Andy
Marv
Andy,
I bonded one with JB Weld. Worked fine. I will check the thickness of a new clutch facing for you tomorrow and post it for you.
Marvin
bowtiebutler956
I would tell you if I was at my shop, but I think Marvin has got you covered. I just rebiult my pto.
Matt
rmaynard
I just rebuilt my pto.
Matt
Where did you get the friction material?
bowtiebutler956
I did'nt get just the friction material, I bought the clutch plate on :techie-ebay: for $60, I also replaced both bearings.
Matt
bowtieguy
Why not buy a new clutch facing (PN 4365) and (6) new rivets (PN 6657) from Toro?...they are still available.
You might want to check the diameter of both PTO "bells"...I think the clutch facing w/rivet holes is smaller that the bonded facing?
WH854
What year did they quit using the small bells, will they work well on a C series tractor ??
Chas
specialwheelhorse
I bonded my last one, didn't completly trust it so I put I think four equally
spaced rivets. Worked fine and purchased it at my local bearing supply of all places.
they just had many different sizes, havent got a clue what for and it only cost me I think about six bucks
about five years ago. Shortly after that I was in a huge John Deere dealer and they had about a bazillion
clutch facings for whatever, so Deere must have a bunch of stuff with about the same facings.
Food for thought JIM in Texas
bowtiebutler956
Say Bowtie, the replacement plate in the picture contacts the machined surface on my bell perfectly, but the original only contacted about 2/3's of the surface area. The new plate pictured is a toro replacement, I just think its an improved design with more holding power. :twocents-02cents:
Matt
BOWTIE
HELLO GUYS, I JUST PUT A DISC ON A SPARE PLATE TODAY. I USED A 2 PART STRUCTURAL ADHESIVE AND CLAMPED IT. TOMORROW I WILL CHECK IT AND WILL ADD HOLLOW STEELL RIVITS. I WILL USE A DREMEL SANDING STONE IN A DRILL PRESS TO BORE THE DISC MATERIAL. THE RIVITS NEED TO BE COUNTER SUNK IN THE DISC MATERIAL. MY DISC MATERIAL IS .125 THICK AND I PLAN ON COUNTER SINKING AROUND .050-.060 DEEP. THIS IS MY FIRST ATTEMPT. I HAVE ONE SPARE DISC MATERIAL AND RIVITS IF ANYBODY IS INTERESTED. THANKS
BOWTIE IN OHIO
Marv
Andy,
I measured the clutch facing and it is .120 thick. This one is a new facing that uses rivets. The one I bonded originally had rivets.
Marvin
wheeledhorseman
Thanks for that Marv :handgestures-thumbup:.
Being as everything is metric here in the UK I make that to be 3mm, just need to source some lining material next.
Good job I asked as I'd have guessed thicker than that - it appears that there was never much 'meat' on these from new.
That's useful information Frank :handgestures-thumbup: - slight issue in the UK is that you can order parts from Toro here but $ converts to £ on a one for one basis :angry: and if there's no stock in the UK you can wait weeks for the next shipment to arrive. :confusion-waiting:
I think I'll just bond the facing and use the PTO assembly itself to apply the necessary pressure - making sure of course that I dont get any adhesive on the wrong side! I think pretty much all automobile type applications use bonded linings these days.
Andy
Don1977
Matt
Check the thickness of the metal new plate, if it's not the same as the old one it will ware out the c-clips. Got one from Toro that was thinner had to put a thin shim behind the plate to fix it.
Kinder, Sr.
Have a Wheelhorse model #101208 s/n 963320, 8hp Kohler, 4 speed.  Need part number for PTO clutch lining.  My diameter is 5".
rmaynard
I don't believe that the lining is still available for your 1973 8HP 4 Speed, but the entire clutch plate #6655 is. You might want to check eBay. Quite often a lining shows up there.
Kinder, Sr.
It's a 6" dia lining that I need, not 5".
jay bee
This post might be helpful.
darjphunter@aim.com
Pto clutch plate for a baler works just grind the center out to fit and about 20$ it's a bit thicker than the other but it's been good for Wheelhorse  guy bedford indiana!
  • Similar Content
    • 87 416-8 horse
      By 87 416-8 horse
      I’m looking for wheel horse tractors for sale or for parts in the Eastern Nebraska or western Iowa area. Preferably 8 speed manuals. Pm me or comment with what you have. The worst I could say is it’s out of my price or distance range. Edit: engine is not important, it’s going to get an engine swap.
      Thanks,
      John
    • BrianStasC-101
      By BrianStasC-101
    • HumbleHans
      By HumbleHans
      Operator manual 810343R1
      Wiring
      34 pages 17.5MB
      Wiring Colored
      1 page 228KB
      1984 C-105 8-Speed model 11-10K802
      1984 C-125 8-Speed model 11-12K802
      1984 C-145 Automatic model 11-14KE01 - Some used alternate inner axle bearing See PSB #369
      1984 C-165 8-Speed model 11-16K801
      1984 C-175 Twin Automatic model 11-17KE01 - Some used alternate inner axle bearing See PSB #369
      1984 C-195 Twin Automatic model 01-19KE02
    • t_furl43
      By t_furl43
      1979 c-101 nice project tractor just needs a few odds and ends, steering wheel, coil, carburetor bowl, the wiring was redone by previous owner....all 4 tires are good and hold air it goes into all gears no problem, transmission fluid has been changed, 10hp Kohler, message me or call or txt with any questions, it does run and runs well,  it’s been kept inside since I’ve had it, I would also trade for a mid mount grader blade thanks
      92DB561C-FF95-4868-A52B-5725D4D3B9DE.mp4
    • RJ Hamner
      By RJ Hamner
      Will the plow I am using on my C121 and C160 work on a 876?
      or is the plow frame different?
      Thanks
      Bob
