cumminscook 60 #1 Posted February 24, 2012 hi guys i have a c-100 i see a lot of b-100 tractors what is the differace between them Share this post Link to post Share on other sites
GlenPettit 1,718 #2 Posted February 24, 2012 Wheel Horse had four 'classes' of Tractors in the 70's & 80's: A-Series = small, very light weight (sheet metal frame), small yard cutting only (was the 100-series in 80's). B-Series = small, light (sheet metal pressed frame), yard cutting & very light towing only (200-series). C-Series = medium-heavy, can use any implement (till, plow, chop), large yard & garden, angle-iron frame, usually larger Kohler engine, 23" tires (became 300-series in 80's). D-Series = very large & heavy duty, large garden, more commercial-size, automotive engines (400 & 500-series). - - - - - Main differences between the B & C tractors; angle-iron vs pressed metal frame, 10 hp Kohler Iron vs Briggs engine, and the C can tow trailers & drive nearly every implement available. Share this post Link to post Share on other sites
Sparky-(Admin) 23,794 #3 Posted February 24, 2012 Glen, the B series in the 80's was the stamped steel frame built for mowing only but the B series from the 70's (B-60, B-80 and B-100) were garden tractors with the angle iron frame and were definitly built for more than just mowing duty. I think the main diff between a B-100 and a C100 is a slightly shorter frame on the B. I'm pretty sure a B-100 and C-100 have the same 8 speed tranny. I had a B-100 a few years back with 1-1/8th" axles which makes me think it had the 8 pinion tranny. Mike........ 1 Share this post Link to post Share on other sites
WheelHorseSteve 56 #4 Posted February 24, 2012 In the mid-70s I'm pretty sure it was just the rear tires and the standard headlight -- the difference between a B-100 & C-100, that is. Install one of those headlights and switch the tires and your B-100 is effectively a C-100. Share this post Link to post Share on other sites
cumminscook 60 #5 Posted February 25, 2012 thanks guys Share this post Link to post Share on other sites
