Sodaking27 1,145 #1 Posted February 22, 2012 Going tomorrow to look at a late model KT-17. It has the stainless muffler and chrome air cleaner. It's off a WH. I've been looking for a replacement motor for my C105. Has anyone here did this swap before. Bigger question is will this motor work on this tractor? The original motor was cradle mounted, I'm guessing the KT-17 would get bolted directly to the frame. Are their any show stoppers in using this engine or should I keep looking for a single slug for a replacement? Share this post Link to post Share on other sites
pfrederi 20,184 #2 Posted February 22, 2012 C 175s used a cradle (shaker) mount. is it a series 2 motor ??? Choke and throttle cables may be an issue as may the PTO hoop. Edit some more thoughts....I converted a C81 to a C175 but used the chrome muffler from 417. I changed the hood and hood stand on the C81 to make it like a C85/175 but the muffler would not clear the hood. Had to modify the front hood hinges to raise the hood and there are some issues with the engine shrouds What model WH is your motor coming from? Share this post Link to post Share on other sites
Sodaking27 1,145 #3 Posted February 22, 2012 Paul, Not 100% sure but I think it's from a 417. Share this post Link to post Share on other sites
pfrederi 20,184 #4 Posted February 22, 2012 The shaker plate and the two cross bars are different for c175 from your c105. If you could get the engine plate from the 417 it would be easier... Share this post Link to post Share on other sites
Sodaking27 1,145 #5 Posted February 22, 2012 Decided against the KT-17. Will keep looking for a 14 or 16 HP single cylinder. Share this post Link to post Share on other sites
mdn1081 1 #6 Posted February 23, 2012 Good choice on finding a single lung. I have a C-175 that my grandfather bought brand new. The Kt-17 is an awesome sounding engine, but problematic. They have been known to throw rods out the side of the block. The series 2 may be better as I think they are pressure lube. Find youself a nice K341. You will have all the power and reliability needed. Share this post Link to post Share on other sites
Sodaking27 1,145 #7 Posted March 9, 2012 Looking at a 16 Magnum. Can I just bolt it to the frame and do away with the shaker plate? The Magnum has the larger old pan. Share this post Link to post Share on other sites
Kelly 1,038 #8 Posted March 9, 2012 yes it will bolt to the frame, if the bottom is drilled on the right side your all set, if not you will have to use J bolts or some other way of attaching the right side to the frame. Share this post Link to post Share on other sites
Sodaking27 1,145 #9 Posted March 9, 2012 Thanks for the info Kelly. Next big part will be figuring out the wiring. Share this post Link to post Share on other sites
