helimech99 0 #1 Posted February 20, 2012 Hi everybody, I have a 1969 Raider 12 that I am restoring and I just finished tearing down the transmission. Everything looks real good inside but I need to replace all the shaft seals and the case seal. I downloaded the manual for the tranny from Toro but it does not list part numbers for the seals, can anyone point me in the right direction for finding the replacement seals. Thanks, Joel Share this post Link to post Share on other sites
bowtiebutler956 650 #2 Posted February 20, 2012 There is a link to toro here in the wheel horse tractor section at the top. Go to the 3rd link down, this will take you to a toro page, just put raider 12 in the box where it says model and hit search, then just click on your model no. It will give you a breakdown of your tractor, click on the transaxle, it will give you all your part numbers and availability. Share this post Link to post Share on other sites
bowtiebutler956 650 #3 Posted February 20, 2012 I'm sorry, put raider 12 where it says product name, not model. I was just there it worked great. Share this post Link to post Share on other sites
Martin 2,133 #4 Posted February 20, 2012 heres numbers for most of the 3,4,6 and 8 speeds........ input 5/8......... 6105 input/brake 3/4.......... 7410 brake/axle 1......... 9815 axle 1 1/8......... 11050 these are c/r (skf) numbers, order through motion industries or napa. 1 Share this post Link to post Share on other sites
rmaynard 16,487 #5 Posted February 20, 2012 Here is the cross-reference chart that has the CR numbers as well as the Toro numbers. http://www.brandywin...ssReference.pdf Share this post Link to post Share on other sites
pfrederi 18,842 #6 Posted February 20, 2012 Or look in the transmission forum (since you are inquiring about transmission stuff) and pinned at the top is a thread on seal and bearing numbers. Share this post Link to post Share on other sites
Don1977 605 #7 Posted February 20, 2012 The Toro seals are all vinyl and a lot of members have had trouble with them leaking. I replaced my input seal and brake seal with after market seals from NAPA "SKF Seals" that still have the metal casing that the vinyl seal is attached. The axle seals I replaced a few years ago I got them from Advance Auto they were " National Seals" with the metal casing. The after market seal may cost a few dollars more but they are worth it. Share this post Link to post Share on other sites
helimech99 0 #8 Posted February 20, 2012 Thanks everybody I really appreciate it. Joel Share this post Link to post Share on other sites
