chevrat68 19 #1 Posted February 19, 2012 Could someone help finding Aftermarket parts for my 2 tractors? First I have a 68 raider 12 that needs a volt regulater, front wheel bearings and I am looking for some bushings for the steering king pins and i am also loocking for the same (except for volt reg) on my 71 raider 14 Share this post Link to post Share on other sites
Kelly 1,038 #2 Posted February 19, 2012 I have used volt regs is used and tested is OK? they don't use busings in the front ends of these tractors, if it's sloppy you need a spindle or the axle is worn, not saying you can't machine the axle to put bushings in, and as for wheel bearings you can go to TSC for cheap bearings about $3 each 1 3/8" OD x 3/4" ID I like using sealed bearings never need to grease them, they run $10 each, they can be had at a bearing store, same size as above. Share this post Link to post Share on other sites
chevrat68 19 #3 Posted February 19, 2012 How much for the reg? and for the bushings thats what i was going to do is drill out the the axle and install bushings just looking to see if anyone has the sizes I should go with. thank you for your your info. Share this post Link to post Share on other sites
Martin 2,134 #4 Posted February 19, 2012 i reamed my 1057 axle and installed 3/4 x 7/8 x 1 inch long bushings. the easiest way to enlarge the hole is to get a hold of a 7/8 construction reamer. the tip is around 5/8 and its tapered back to the 7/8 on the chuck end. dont have any pics but heres how i did the clutch pedal on the same tractor. same size bushings.... purchased the bushings through mcmaster carr but you might find them at tsc or farm and fleet type stores. make sure the axle casting is whats worn though....... Share this post Link to post Share on other sites
TT-(Moderator) 1,185 #5 Posted February 19, 2012 A 1968 Raider 12 can have a starter/generator (early) or a gear starter with alternator. (late) You need to specify which type when asking for a "volt regulator". Share this post Link to post Share on other sites
