jdog_kustoms 82 #1 Posted February 16, 2012 this pulley came off of an engine of a old wheel horse with a starter generator but it was about 5 tractors made in to one was wondering if anyone knew what tractor this came off of or if it is even factory wheel horse Share this post Link to post Share on other sites
sorekiwi 761 #2 Posted February 16, 2012 1057? Whats the bore size and OD? Share this post Link to post Share on other sites
buckrancher 2,697 #3 Posted February 16, 2012 if it has a 1 inch bore it looks like something that could have been used as the add on motor pulley for the hy-2/hy-3 kits? Share this post Link to post Share on other sites
jdog_kustoms 82 #4 Posted February 16, 2012 it is an 1 1/8 bore not sure on the out side and i forgot were i put the pulley to measure but was off a k 241 Share this post Link to post Share on other sites
Kelly 1,039 #5 Posted February 16, 2012 My 1257 has one like that, it has the holes for the clutch plate to bolt to, but is still the old 2 1/2" diam. Share this post Link to post Share on other sites
TT-(Moderator) 1,188 #6 Posted February 16, 2012 Normally found on 1046, 1056, 1057, 1257, 1067, & 1267 models, but can also be used to convert the 1045 & 1055 models to the engine-mounted PTO. Share this post Link to post Share on other sites
jdog_kustoms 82 #7 Posted February 16, 2012 ok cool now i know what it is so i can list it correctly Share this post Link to post Share on other sites
kpinnc 19,105 #8 Posted February 16, 2012 Normally found on 1046, 1056, 1057, 1257, 1067, & 1267 models, but can also be used to convert the 1045 & 1055 models to the engine-mounted PTO Also looks quite a bit like a part from the PT-6 and PT-7 kits. It was for adding a regular (or "new", at the time) PTO to an older tractor with the 3-groove pulley setup. Share this post Link to post Share on other sites
jdog_kustoms 82 #9 Posted February 16, 2012 is it worth anything Share this post Link to post Share on other sites
Kelly 1,039 #10 Posted February 16, 2012 Only if you need it. :ph34r: Share this post Link to post Share on other sites
sorekiwi 761 #11 Posted February 17, 2012 is it worth anything I dont really know. I have one here (from my 1057), and that engine is now in my 1054. If Kelly ever gets round to selling me a 1054 pulley, then I'll have this little pulley sitting on the shelf!!! :) 1 Share this post Link to post Share on other sites
Kelly 1,039 #12 Posted February 17, 2012 I hear you I need to try again to get the pulley off, it's yours someday :hide: 1 Share this post Link to post Share on other sites
