C-85
Pictures of front weight project
C-85
I recently took a welding course and had to come up with a project to work on. So I decided to come up with a front weight carrier for the front of my C-85. Since I added my heavy duty rear weight box, the front has been a little light, so I wanted to add some additional weight to the front of it. My goal was to make a weight carrier that would clip into the front tach-a-matic with no tools and be large enough to carry a selection of weights and not interfere with the plow and this unit just clears all angles of the plow. This also rests on the tach-a-matic's frame, not the rods that go across it for extra strength. Most of this is made of 1/4" rectangle steel tubing, a piece of 5/8" rebar, and a piece of channel iron, plus an old Ariens 1" snoblowers front rotor shaft.
The shaft or bar that's holding the weights in place is just sitting in a 1" hole. I left it this way so I can quickly remove it and some of the weights if I need to tilt the hood up all the way.
It was a fun project and I wanted to share it with all you folks! :USA:
C-85
post-2212-0-77894200-1329090800_thumb.jp
post-2212-0-27943700-1329090886_thumb.jp
post-2212-0-92033100-1329090933_thumb.jp
post-2212-0-04727100-1329091000_thumb.jp
post-2212-0-01938100-1329091188_thumb.jp
post-2212-0-75156500-1329091269_thumb.jp
post-2212-0-39764900-1329091364_thumb.jp
post-2212-0-41262000-1329091449_thumb.jp
post-2212-0-97545400-1329091537_thumb.jp
post-2212-0-07340500-1329091618_thumb.jp
post-2212-0-99427200-1329091698_thumb.jp
Duff
Yo, Dennis! That's a nice build! May have to hire you to build a second one for one of my herd across the river!
:thumbs: Duff :thumbs:
rexman72
very good idea and project
kpinnc
Looks good Dennis! Makes me wish mine had better clearance underneath like yours does.
C-85
Sorry Duff,
Vermont Customs agents wouldn't allow this technology to cross the river :wub:
  • Similar Content
    • Tim's Toy Tractor
      By Tim's Toy Tractor
      Seat, New! Universal Garden Tractor / Riding Mower Seat
      This is a new seat that I purchased for a project tractor and never used, it is in Perfect as New Condition.
      I have used this seat on a few Wheel Horse tractors, and they have been a perfect fit and look great.
      This is a Universal fitment seat; it has multiple mounting holes and mounting patterns for fitment on most Graden Tractors and Riding Mowers.
      $49.00  Call Tim @ 1-313-460-8858     (Local Pick-Up Only, No Shipping)
    • Tim's Toy Tractor
      Two 3 Rib Firestone Tires, 16x6.50-8, 2 of them mounted on OEM Wheel Horse Rims, NEW!
      These tires are New, Never Used! Not the cheap China ones, these are High Quality Firestone Tires!
      Great for any Garden Tractor or Riding Mower
      They are mounted on original Wheel Horse wheels that have been sandblasted & epoxied, and painted with ivory colored paint, note there are a few chips along the inside bead from mounting the tires. The rims will need your specific size wheel bearings installed.
      $99.00 Call Tim @ 1-313-460-8858        (Local Pick-Up Only, No Shipping)
    • Tim's Toy Tractor
      C - Series, Hood and Sheet Metal (square black insert) (also known as black hood models) for sale!
      This sheet metal set, including C Series Hood, Dash piece, Seat Bracket, and Left & Right-Side Covers, and Left & Right Floorboards was sandblasted, epoxy primed, and painted the OEM Wheel Horse Red Paint.
      The painted set is not perfect, a little metal pitting on one of the floorboards, a few little imperfections in the paint here and there as I'm a rookie painter, but this is a nice painted set of sheet metal to freshen up your C Series Wheel Horse!
      $140.00 O.B.O. Call Tim @ 1-313-460-8858        (No Shipping, Local Pick-Up Only)
    • Deer hunter
      By Deer hunter
      Does anyone know where I could find a complete engine rebuild kit from for the k-19 ? I absolutely love my c-195 and have had it for years. But the motor let go last fall and I want to rebuild it or upgrade the motor, any suggestions?
    • BrianStasC-101
      By BrianStasC-101
