Big Jake 18 #1 Posted February 12, 2012 my 310-8 can someone tell me if it is a 8 or 10 pinion dif. Thanks Share this post Link to post Share on other sites
Sparky-(Admin) 25,934 #2 Posted February 12, 2012 Are the axles 1"? They probably are which tells me you have the 4 pinion rear and not an 8. The 10 was offered on the late 60's/early 70's machines like the Raider. Mike............ Share this post Link to post Share on other sites
Kelly 1,038 #3 Posted February 12, 2012 But some 1 1/8" axles are only 4 pinion diffs Share this post Link to post Share on other sites
Sparky-(Admin) 25,934 #4 Posted February 12, 2012 Blasted Wheel Horse....theres an exception to every rule Kelly ! Mike......... Share this post Link to post Share on other sites
Duff 206 #5 Posted February 13, 2012 If it's a "stock" original 310-8, it'll have 1" axles and a four pinion diff. But like so may 'horses, it could have had some organ transplants along the way! Duff :thumbs: Share this post Link to post Share on other sites
kpinnc 18,740 #6 Posted February 13, 2012 There was a theory (rumor, urban legend, whatever) that said some of the 310-8 tractors had 4 pinions with 1-inch axles, but the axle carriers had the 4 additional holes to add 4 more pinions. Even the Toro MPV showed them that way, which may very well be where the story got it's start. I have never seen one myself, and I have opened several cases in the hunt for such a thing. More than likely- just as Duff said, you have 1 inch axles and a 4-pinion differential. Lighter duty than the 8-pinion, but still a very rugged unit. Unless you plan to pull stumps regularly with it, it should do anything you ask without breaking. Share this post Link to post Share on other sites
can whlvr 994 #7 Posted February 14, 2012 i hoped my 2 1 inch axle rear ends had the spots for more pinions but not to be,4 pinion only Share this post Link to post Share on other sites
