WH854
Plastic Gas Tank Project
WH854
Under Seat Gas Tank!! Removing old shut of valve and installing a new one.
Here is my way of doing it.
First I heat up the area around the valve with a Hair Dryer I used the hi setting
Hair Dryer
Next picture shows gas tank in vice.
I heat up around the valve to soften the plastic then I pull on gas tank and here are the results.
Gas Tank
Shutoff valve
Picture of new valve and grommet
Next I cleaned the tank up a little bit and smeared petrolum jelly on the hole in the tank also on grommet
Tank
Grommet
Installed grommet
Then The Shutoff Valve
This is my third one, takes about a half hour to do it this way. You have to be careful after 30 or so years the plastic get brittle.
Hope this helps some one that needs to do one.
Chas
AMC RULES
Looks easy enough. :thumbs:
Rollerman
:text-goodpost: The only thing I'll add is make sure the tank is clear & not a potential source of fumes, hairdryers can make a potential ignition source.
WH854
Good point, this one was on the shelf for a while :thumbs:
Chas
JamesBe1
Nice job!
Where did you source the valve and grommet?
dobeleo
I was worried when i took mine apart. I washed the tank with hot soapy water in the kitchen (the wife was real happy with that)
lubed everything up and slipped together, I used the same valve and took off the screen, it was all rusted. I figured I would add an in line filter anyway.
I put gas in it for a while, and lucked out, no leaks!
Dan
Shorewood, IL
WH854
Nice job!
I got mine on ebay !! You may be able to get them at lawnmower repair shops :thumbs:
Chas :wh:
PS they are still Avalable from Toro they cost about $19.00 for both
P/N 46-6560 - BUSHING
P/N 104048 - VALVE-FUEL
