200 series Peerless transmission brake overhaul
By
wheeledhorseman, in Transmissions
Similar Content
By eo1bart
Looking for a gearbox with 1 1/8" axles for my 312. Ok if it needs rebuilding.
Located in the New England area
By cheesegrader
About a decade ago, I bought a conversion kit here to remove the column drive lever and convert to a foot pedal for a 520h.
I would like to convert a second tractor, and I need to replace one of the linkage bars on the first one that has cracked, but I can't find the vendor any more.
Does anyone remember who made this awesome mod, and where I can find them?
By giant_g2
By wheeledhorseman
Operator manual #810296R1
4 pages 848.00KB
2 pages 171.30KB
Fits
1983 B-Series and LT-Series See Product Service bulletin
1984 B-Series and LT-Series
1985-1986 200-Series
For vertical shaft 200 series models 1985 onwards but was also used with 1979-80 B series models (supplied with different lift rod) Fits for example B-165 or 216-5.
Dozer 1983 42in model 06-42BB02 Complete
1983 serial numbers that have shown up for the 06-42BB02
19345
20452 - Build date 1983 3259 September 16 Friday
20551 - Build date 1983 3259 September 16 Friday [259] Guess
Dozer 1984 42in model 06-42BB02 Complete
1984 serial numbers that have shown up for the 06-42BB02
23294 - Build date 1984 4193 July 12 Thursday
Dozer 1985 42in model 06-42BB02 Complete
Dozer 1986 42in model 06-42BB02 Complete
Link to service bulletin
http://www.wheelhorseforum.com/files/file/469-wh61-90-315-snow-equipment-1982pdf/
By Doug B
Hey guys,I have a dilemma I need some help with. I have a 1969 GT 14 that I replaced the transmission and pump on. For about 2 weeks afterward everything worked great, but while mowing at a pretty good pace I noticed a shudder and the tractor slowed a little but not bad. The more I rode it the slower it got until it barely moves. What stumps me is the hydraulics are still very strong,as in I can back the 3 point under the bumper of my truck and if you lift the arms all the way up the front wheels of the tractor will clear the ground. Have checked the tow valve and checked the internal filter,but no luck. I have also checked and replaced the forward and reverse bypass springs and the lever is moving the cam to full travel, forward and reverse. Any help would be appreciated.
