Paul D.
Cable diameter
Paul D.
I'm installing my rock shaft tomorrow and I am wondering the best dia. cable to use from the lift arm to the rock shaft. I looked for a strength rating online and haven't found the answer I am looking for yet so... what did you all use and have any of you figured out what is to small(a.k.a. Ya broke something) what is the limits of what the hyd. lift on these tractors will do anyway. I see homemade attachments with cinderblocks strapped to them. That seams like an awful lot of weight for a little cable to be lifting. I welcome all thoughts. Thanks,
TT
3/16" seems to be the normal size, but I would be more concerned about how well the ends are secured vs. the actual cable strength.
I used a parking brake cable from an 80's Ford Mustang for the last one I made up. Best part was, It was plastic coated and one of the ends was already on the cable. :handgestures-thumbup:
Raider10
Going to do the same myself. I work on diggers and telescopic handlers etc here in England and have saved a hand brake cable off a JCB telehandler. As TT says they come half made and even have the correct yoke on the end to fit my lift lever, although mine isnt hydro.
When I did my raider 10 rear lift i only used 1/8 cable with small u bolts as clamps and that will lift me quite easily And i weigh about 90 kilos.
Ian :ychain:
specialwheelhorse
Tailgate cables on some pickup's are nearly long enough. with a short piece of chain or clevas
or whatever on the rockshaft end to make up length, they have rock solid ends on and are
coated very well.
Jim in Texas
TT
Here's two of my most recent hoarded/pack ratted/recycled items......
A (broken) parking brake cable from a Toro Sand Pro 5040 and a slightly-used temporary service brake cable from a Club Car "golf" cart:
They should make some nice lift cables, eh? :handgestures-thumbup:
Don1977
Hand brake cable from rear wheel drive Ford is some tough stuff. I have a piece with a ball end I am saving for another cable. I have used garage door cable also. I brazzed one end into a 5/16" bolt that I had drilled out, but I had to use too much heat with the brass and burnt the cable. I plan to silver solder the next one as it doesn't take as much heat.
Paul D.
Got it all installed this afternoon. Thanks for all the input. It's really nice to be able to learn from those that have already been there. :handgestures-salute:
  • Similar Content
    • Tim's Toy Tractor
      By Tim's Toy Tractor
      Seat, New! Universal Garden Tractor / Riding Mower Seat
      This is a new seat that I purchased for a project tractor and never used, it is in Perfect as New Condition.
      I have used this seat on a few Wheel Horse tractors, and they have been a perfect fit and look great.
      This is a Universal fitment seat; it has multiple mounting holes and mounting patterns for fitment on most Graden Tractors and Riding Mowers.
      $49.00  Call Tim @ 1-313-460-8858     (Local Pick-Up Only, No Shipping)
    • Tim's Toy Tractor
      Two 3 Rib Firestone Tires, 16x6.50-8, 2 of them mounted on OEM Wheel Horse Rims, NEW!
      These tires are New, Never Used! Not the cheap China ones, these are High Quality Firestone Tires!
      Great for any Garden Tractor or Riding Mower
      They are mounted on original Wheel Horse wheels that have been sandblasted & epoxied, and painted with ivory colored paint, note there are a few chips along the inside bead from mounting the tires. The rims will need your specific size wheel bearings installed.
      $99.00 Call Tim @ 1-313-460-8858        (Local Pick-Up Only, No Shipping)
    • Tim's Toy Tractor
      C - Series, Hood and Sheet Metal (square black insert) (also known as black hood models) for sale!
      This sheet metal set, including C Series Hood, Dash piece, Seat Bracket, and Left & Right-Side Covers, and Left & Right Floorboards was sandblasted, epoxy primed, and painted the OEM Wheel Horse Red Paint.
      The painted set is not perfect, a little metal pitting on one of the floorboards, a few little imperfections in the paint here and there as I'm a rookie painter, but this is a nice painted set of sheet metal to freshen up your C Series Wheel Horse!
      $140.00 O.B.O. Call Tim @ 1-313-460-8858        (No Shipping, Local Pick-Up Only)
    • Deer hunter
      By Deer hunter
      Does anyone know where I could find a complete engine rebuild kit from for the k-19 ? I absolutely love my c-195 and have had it for years. But the motor let go last fall and I want to rebuild it or upgrade the motor, any suggestions?
    • BrianStasC-101
      By BrianStasC-101
