Paul D.
Cable diameter
Paul D.
I'm installing my rock shaft tomorrow and I am wondering the best dia. cable to use from the lift arm to the rock shaft. I looked for a strength rating online and haven't found the answer I am looking for yet so... what did you all use and have any of you figured out what is to small(a.k.a. Ya broke something) what is the limits of what the hyd. lift on these tractors will do anyway. I see homemade attachments with cinderblocks strapped to them. That seams like an awful lot of weight for a little cable to be lifting. I welcome all thoughts. Thanks,
TT
3/16" seems to be the normal size, but I would be more concerned about how well the ends are secured vs. the actual cable strength.
I used a parking brake cable from an 80's Ford Mustang for the last one I made up. Best part was, It was plastic coated and one of the ends was already on the cable. :handgestures-thumbup:
Raider10
Going to do the same myself. I work on diggers and telescopic handlers etc here in England and have saved a hand brake cable off a JCB telehandler. As TT says they come half made and even have the correct yoke on the end to fit my lift lever, although mine isnt hydro.
When I did my raider 10 rear lift i only used 1/8 cable with small u bolts as clamps and that will lift me quite easily And i weigh about 90 kilos.
Ian :ychain:
specialwheelhorse
Tailgate cables on some pickup's are nearly long enough. with a short piece of chain or clevas
or whatever on the rockshaft end to make up length, they have rock solid ends on and are
coated very well.
Jim in Texas
TT
Here's two of my most recent hoarded/pack ratted/recycled items......
A (broken) parking brake cable from a Toro Sand Pro 5040 and a slightly-used temporary service brake cable from a Club Car "golf" cart:
They should make some nice lift cables, eh? :handgestures-thumbup:
Don1977
Hand brake cable from rear wheel drive Ford is some tough stuff. I have a piece with a ball end I am saving for another cable. I have used garage door cable also. I brazzed one end into a 5/16" bolt that I had drilled out, but I had to use too much heat with the brass and burnt the cable. I plan to silver solder the next one as it doesn't take as much heat.
Paul D.
Got it all installed this afternoon. Thanks for all the input. It's really nice to be able to learn from those that have already been there. :handgestures-salute:
  • Similar Content
    • Deer hunter
      By Deer hunter
      Does anyone know where I could find a complete engine rebuild kit from for the k-19 ? I absolutely love my c-195 and have had it for years. But the motor let go last fall and I want to rebuild it or upgrade the motor, any suggestions?
    • BrianStasC-101
      By BrianStasC-101
    • HumbleHans
      By HumbleHans
      Operator manual 810343R1
      Wiring
      34 pages 17.5MB
      Wiring Colored
      1 page 228KB
      1984 C-105 8-Speed model 11-10K802
      1984 C-125 8-Speed model 11-12K802
      1984 C-145 Automatic model 11-14KE01 - Some used alternate inner axle bearing See PSB #369
      1984 C-165 8-Speed model 11-16K801
      1984 C-175 Twin Automatic model 11-17KE01 - Some used alternate inner axle bearing See PSB #369
      1984 C-195 Twin Automatic model 01-19KE02
    • t_furl43
      By t_furl43
      1979 c-101 nice project tractor just needs a few odds and ends, steering wheel, coil, carburetor bowl, the wiring was redone by previous owner....all 4 tires are good and hold air it goes into all gears no problem, transmission fluid has been changed, 10hp Kohler, message me or call or txt with any questions, it does run and runs well,  it’s been kept inside since I’ve had it, I would also trade for a mid mount grader blade thanks
      92DB561C-FF95-4868-A52B-5725D4D3B9DE.mp4
    • RJ Hamner
      By RJ Hamner
      Will the plow I am using on my C121 and C160 work on a 876?
      or is the plow frame different?
      Thanks
      Bob
