1maidenfan
18 auto ( sundstrand)hydro motor strainer
1maidenfan
Looking for a strainer filter for my 18 auto hydro motor. Tried going to toro to order one but like most parts for these tractors they are N.L.A. :eusa-think:
Any one know where I can get one? Mine is no good.
Thanks.
can whlvr
sorry to hear its wrecked,with all the bad hydros ive read about someone must have one,keep trying and i would post in the wanted area too
JamesBe1
I was wondering around my local tractor supply this afternoon, and I came across a hydro filter that I wanted to check out further on the net. They are from a company called Lenz. I was going over their website, and they have several different strainers. Mayhaps they have something that you can modify to you ends.
http://www.lenzinc.com/productfamily_list.php?id=TkRVJTNE
coldone
Check with an industrial plumbing supplier. The Wye (Y) strainer has mesh screens that go down to 20 microns. Dont tell them you are looking for hydraulic screens, they wil laugh at you. You will have to modify it but it should work.
Hodge71
The pump itself doesnt have the filter on it. It sits in a recess in the transmission housing. Finding them is like hens teeth. I got a nos 1 for mine off fleabay back in February
1maidenfan
I ended up getting one from one of our redsquare members.
Thanks guys :text-thankyouyellow:
  • Similar Content
    • tractorboy79
      By tractorboy79
    • BuffaloD200
      By BuffaloD200
      '74 D-180
      My friction disc in gone on my clutch.  I saw the old post about making a new friction disc, so I'm not concerned about that.
      I managed to remove the front clutch plate and double v-belt pulley.  But I can't separate the two.  When I took the assembly off the spiraloc washer popped off on its own.  I HAVE READ THE MANUALS.
      So I should be able to just remove the pulley from the front clutch and continue with step 4.  The v-belt pulley is loose as all hell and flops around like a dead fish.  It seems to be hung up on a ring or bearing race.
      So my thoughts are grab a BFH or sparky the blue tip wrench.
      Is there an unpublished step 3.5, or some trick?
    • BuffaloD200
      By BuffaloD200
      Hey all,
      My '74 D180 has a lot of trouble pushing snow.  Weighted tires, but nothing else at this time.  I've found it gets stuck frequently and only one wheel spins.  Do these tractors not have a limited slip/locker arrangement?  How does everyone manage with the infamous one wheel peel?
    • BuffaloD200
      By BuffaloD200
      Hey all, I need to install a drive belt on my 75 D180 for my snowblower.  I've looked through a bunch of D-series owner's manuals, and none seem to mention replacement procedure.  The PTO pulley is fixed, save for engaging the PTO and there is minimal movement at the snowthrower pulley. There's no idler or tensioner as far as I can tell.  Do I have to remove the PTO pulley?  That seems to be a required service item.
      Same question for my 80 D200 as well really.
      Using the recommended 4L490W belt.
      Thanks
    • ihatephones
      By ihatephones
      I got a D-180 for $250, and the governor is messed up, the points won't open or close, and I took it apart and was being stupid and messed some stuff up in there, and now I need a new one.
      Where can I get one that's not on eBay for $200?
      I also forgot to say it was a Kohler K482, and I'll throw some pictures of the tractor in as a treat.
