chesbaycruiser
Help - Feasibility of Upgrading K-181 to K-241 or K-301
chesbaycruiser
I'm looking for a little advise here.
As mentioned in another post, the K-181 in my 1975 B-80 had massive internal failure. Initially, I thought the only damage was the rod and piston, but after a thorough cleaning and some additional inspection, I realized that there was a chunk missing from the bottom of the cylinder wall. I had one engine shop tell the me the damage is low enough and small enough that it shouldn't matter, however the machine shop was not so confident, basically saying it MIGHT be fine.
That means I'm looking at $225 in machining costs plus about $150 in parts to repair an engine that may or may not be repairable. My initial thought was at that price point, it would be worth the relatively small investment to pick up a used block, but that got me thinking even further....if I'm spending the money anyway, what if I wanted to upgrade?
I've done some searching here on the forum about engine swaps but I'm still a little unsure, so I apologize in advance if I'm asking a "what is the correct color" type of question!
What I'm wondering:
  • Is the K-241 (10 hp) or K-301 (12 hp) a direct bolt-on replacement for the K-181 (8 hp)? If not, what sort of mods am I looking at?
  • What if it's not a Wheel Horse (Cub, Deere, Ariens, etc) engine? Is there a good resource for knowing which ones will work, or what to look for?
  • In a related question, what if I purchase another K-181 block but it's from a non-WH machine, assuming I'm replacing all the guts, are the blocks fairly universal, or are they different depending on their original application?
I welcome your comments and/or links to threads that have already covered these issues.
Thanks in advance for your input!
CB
Rollerman
Your K181 sits on a riser plate in the B-80.
With the plate removed any Wheel Horse spec solid mount big block single will bolt right in.
The shaker mount engine probably will not work since the B 80 frame is just a little shorter.
Other non Wheel Horse spec engines can be adapted, just have to watch the oil pans.
Some can be swapped for the Horse style, others can't be.
pfrederi
Make sure that the crankshaft is long enough. WH Spec cranks stick out over 3 inches (I m sure some one knows the exact length. Other brands speced engines with shorter crankshafts.
chesbaycruiser
Showing my ignorance here...."shaker mount"? :scratchead:
TT
The majority of the '78 to '84 C series tractors used a rubber-mounted isolation cradle bolted to the engine in an attempt to decrease vibration felt by the operator.
K-181 engine blocks were basically the same and it shouldn't be too hard to track one down - if you decide to pursue that option.
rmaynard
Another thing is that the K-181 has a 1" crankshaft. Wheel Horse K241/301's have 1-1/8" cranks. That means that the PTO will have to be equipped with a different bearing race, and the drive pulley will have to be changed.
chesbaycruiser
Thanks for all the input. Very helpful.
What I didn't think to ask (the machine shop or in my post above)....is there a good reason why I couldn't get the cylinder in the K-181 sleeved?
sorekiwi
This is my old B-80 with a K341 in it.
I think all the points have been covered by everyone else, except I found my throttle and choke cables were too short to reach the correct places on the big block engine. I just swapped in a complete dash from a C160 that I had here.
I dont remember which exhaust I used. The big block exhaust exits the motor at a different angle than the small block. I dont remember if I modified the K181 one or whether I used a C160 one.
can whlvr
one other thing to consider is do you want or need more power,if so then that will answer to use the old one or not,im no expert but it probally could be sleeved
HorseFixer
WoW!! A B-160 has a nice ring to it! :thumbs: I'm likin it! :whistle:
Cheers ~Duke
:beer:
hm12460
CB, Don't under estimate the K-181. They will do a lot more than most people think they will. A John Deere 110 spec K-181 will also fit your B-80 and might be a little bit easier to find. I see them around occassionally.
chesbaycruiser
hm,
"CB, Don't under estimate the K-181. They will do a lot more than most people think they will...."
I have NO complaints about the power of the 8-hp! My only reason for considering switching it out was to expand the pool of available engines.
As it turns out, a friend and I picked up a C-85 "parts tractor" and a C-81 in pretty nice shape (that he will refurb) this weekend. I got the engine running (short video) on the C-85, but it smokes like a chimney. Result: Now I have two engines that need rebuilding. On the upside, at least I know this one doesn't have a piece missing from the cylinder!
rmaynard
That's not too bad. Hope you find that a simple refresh takes care of the problem.
  • Similar Content
    • aaronthomas57
      By aaronthomas57
      Hello Everyone,
      The information here has been invaluable as far as getting this old wheel horse I purchased back in service. Some parts home made, the motor generator is ripped off a 2013 Yamaha, some salvaged parts.
      I bought this little bastard some months ago, it had to be dug out of the previous owners yard and lifted with a backhoe. It had not ran in about 40 years.
      Thanks for taking a look.
    • Bill D
      By Bill D
      I have a GT1800 that I have swapped an M14 into.  The original drive belt is too long for the Kohler.  I tried a 7473 belt and that was too long.  I'm guessing I need an 81" belt.  Does anyone know for sure?  I'm thinking it should be the same length as a 314H?   I'm trying to avoid multiple trips to TSC with the price of gas.  Yes, I do have the correct hydro pulley on the Kohler.  Thanks.
    • tomabrown77
      By tomabrown77
      my 1067 stopped moving; limited slip had worn out long ago;  now input pully is turning , but tractor doesnt move --- very slight motion forward or backward if on level ground with no resistance.  Enough to tell me shift lever is actually changing gears.
      I suspect input shaft woodruff keys but might be something worse ... i am interested in perhaps buying a new, used,or rebuilt  transaxle if someone has one they would part with.  And any advice on opening up the transaxle and looking inside .  Or where i can find parts to rebuild it myself...
      ps i was on forum about 5 years ago,  forgot my username so i joined again
    • BAM1
      By BAM1
      Starting a slow restore to a C-160, Today she got a new fuel tank, and different tires. Started it up and went for a ride under her own power, first time since '08.
      Next comes finding the fuel leak, looks like a bad hose. and maybe some cleaning of the oily parts.
    • stevasaurus
      By stevasaurus
      I finally got a chance to rebuild a transmission with a hi/low mechanism.  This is a 6 speed #5060 transmission with the 10 pinion limited slip differential.  Notice the brake shaft comes out the hole closest to the axle housing.  The 8 speeds brake shaft comes out of the cluster shaft hole.  I did a series of videos for this thread along with some pictures.  The videos are split up between different phases of rebuilding...ie...the differential, the hi/low shift mechanism, the rest of the gears 1 & 2 (my batteries died in the camera).  Most of the information will be in the videos...be advised that I did some struggling while doing these videos and I left them as is because it is not always easy.    Hope this helps you guys.
      correction...
      According to the manual the bolts that hold the differential together are in backwards in the video.  The nuts should be on the input shaft side (right side) of the transmission.  Sorry, I missed that.
      Just got the trans split.  I use a 1" old wood chisel to start and then work the case apart with a pry bar.
      A couple shots after getting the case half off...trans is in neutral.
      The trans case works as a work bench for the differential...very cool
      Here is the reason the trans needed to be opened.  An axle gear lost it's teeth and the pieces were lodged in the pinions.
      Finished and back together.
      The rest are the videos...1st on is the differential...
      Next 2 are dealing with the hi/low mechanism...1st one taking apart and the 2nd on putting together...be nice...it was my first time.
      Now, 2 videos putting the rest of the trans together...batteries died just before I finished the first video.
      Thanks for looking
