edur1710 0 #1 Posted January 21, 2012 i have a 314-8 just put a new battery in it about a month ago its been hooked up to the battery tender all winter long went to start it nothing at all. hooked the charger up and the starter is spinning but not turning the engine over whats goin on?? Share this post Link to post Share on other sites
CTPATRIOT 12 #2 Posted January 21, 2012 Try tapping the starter while cranking it.Could also need more juice... Share this post Link to post Share on other sites
edur1710 0 #3 Posted January 21, 2012 i tapped the starter a little bit and it didnt help any.. think maybe it could be a fuse or something?? Share this post Link to post Share on other sites
CRE1992 143 #4 Posted January 21, 2012 No, not a fuse, try cleaning the starter and battery grounds, and connections on the solenoid. If it still doesn't engage the flywheel the Bendix could be stuck. Or your battery doesn't have enough cold cranking amps. Share this post Link to post Share on other sites
edur1710 0 #5 Posted January 21, 2012 alright that goin to be tomorrows project after work it ran fine up until about a week ago i dunno whats goin on? Share this post Link to post Share on other sites
Forest Road 594 #6 Posted January 21, 2012 Put a set of jumper cables on it. You might have too small a battery for this cold weather. Share this post Link to post Share on other sites
pfrederi 19,270 #7 Posted January 21, 2012 i have a 314-8 just put a new battery in it about a month ago its been hooked up to the battery tender all winter long went to start it nothing at all. hooked the charger up and the starter is spinning but not turning the engine over whats goin on?? If teh starter is spinning at full speed but not moving the engine your pinion is stuck. Quick fix is to try to spray some electrical contact cleaner (or even brake clean in there.) After teh snow you should pull the starter motor and clean teh pinion shaft . Share this post Link to post Share on other sites
Sparky-(Admin) 23,986 #8 Posted January 21, 2012 After its clean you should get some powdered graphite to lube it up. No liquids (oils) or greases as they will allow any grit and crud to stick to the starter gear shaft. Mike........ Share this post Link to post Share on other sites
edur1710 0 #9 Posted January 21, 2012 yeah i'll try that today when i get home i got about 8 inches of snow to deal with so it has to run today i gotta get my snow plowed!! Share this post Link to post Share on other sites
edur1710 0 #10 Posted January 21, 2012 put a new battery in it and works fine must have been a bad battery and that battery was only a month old Share this post Link to post Share on other sites
Sparky-(Admin) 23,986 #11 Posted January 21, 2012 Great news! Can the old battery be returned? Mike........ Share this post Link to post Share on other sites
edur1710 0 #12 Posted January 21, 2012 I think so its only a month old good thing the battery in my c-161 is brand new too lol Share this post Link to post Share on other sites
SAM58 31 #13 Posted February 3, 2012 i HAD A SIMILAR PROBLEM, HAD TO REMOVE THE STARTER AND CLEAN OUT JUNK AROUND THE BENDIX... STARTER WOULD SPIN, BUT WOULD NOT ENGAGE. FIXED MY PROBLEM. Share this post Link to post Share on other sites
