BairleaFarm 340 #1 Posted July 1, 2008 Im thinking about buying a c-81 thats all I know about it. No year no nothing. Tell me the good the bad and the ugly on this tractor if you wouldnt mind. Thanks David Share this post Link to post Share on other sites
rocking 416 1 #2 Posted July 1, 2008 Hmm maybe 78-79 not 100% sure ......i have two a 78-an 79 there good tractors need some tlc the decks dont seem to last. only thing i can say thats bad about them Share this post Link to post Share on other sites
BairleaFarm 340 #3 Posted July 1, 2008 Are they hydro drive of is it set up close to my 73 4speed? Share this post Link to post Share on other sites
TT-(Moderator) 1,162 #4 Posted July 1, 2008 Why do you want to buy it? Do you have a particular purpose or need for it, or is it just because it's a Wheel Horse? How much is the asking price? Otherwise, it is what it says it is - a C-81. It is naturally an 8 speed because the hydro was not offered in the 8hp B&C models. The transaxle has an 8 pinion differential and 1 1/8" axles, which is the strongest gear Uni-Drive model made. It has a K-181 engine, identical to the tractor you have now, except it is rubber-mounted to the frame. Share this post Link to post Share on other sites
rocking 416 1 #5 Posted July 1, 2008 i have not seen a hydro drive c81 . That does not mean they dont exist, i dont belive they do . the one in your picture looks to be a 8 speed uni drive . and i do not no anything about a 4 speed .. i would have to re check my numbers but i think if the serial number is on the dash panel near the shifters its a 1978 my 1979 has the serial numbers near the steering gears Share this post Link to post Share on other sites
TT-(Moderator) 1,162 #6 Posted July 1, 2008 And you can always go to Toro.com and look this stuff up. Use 91-08K801 for a model number. Clicking on the "view product features" link will get you the basic information. You can also look at the IPL while you're there. Share this post Link to post Share on other sites
BairleaFarm 340 #7 Posted July 1, 2008 Its 300$neg comes with a deck, plow, chains, wheel weights, and a non WH dump cart. I want another mower as my current one has just died. And yes I want this one because its a WH. Tractor starts but only runs for a few minutes. Until I get my other one back together(might be awhile) I will be using this to mow. Occasionally using the blade as well. Share this post Link to post Share on other sites
TT-(Moderator) 1,162 #8 Posted July 1, 2008 If the attachments are in good condition, and the tractor isn't worn out with bad tires, etc., that's not a terrible price. I'd be a little concerned with the "shutting off after a few minutes" deal, but that could be as simple as a fuel delivery problem or a bad ignition coil. I only asked what your intentions were because too many people expect the 8hp tractors to do the work of the big block powered machines and end up disappointed with them. The 8hp Kohler will run a 36" mower deck well, and - under the right conditions - a 42" deck isn't beyond their capability. If the tractor was properly maintained, it should be good for many more years of service. :whistle: Share this post Link to post Share on other sites
BairleaFarm 340 #9 Posted July 1, 2008 I can push mow my yard in 1 hour so I dont think ill over work her. Its more of a hobby. Ive spent the last 4 years convincing my some what gullible wife i needed a riding mower. Price is decent for around here comparably speaking. (i figure fuel prices for P/u) kinda slim pickings as far as lower priced wheel horses in this area. Share this post Link to post Share on other sites
mcwh1950 2 #10 Posted July 1, 2008 as tt said i use my c81 for cutting grass and hauling the wagon around the yard i use a 36 rd deck on it. had no problem whit it for the last 4 year. Share this post Link to post Share on other sites
