NYRedNeck 4 #1 Posted December 9, 2011 Hey Guys, I am going to look at a WH this weekend. I am told it is an early WH tractor with the straight axle so I believe it is an RJ and not a Suburban. It supposedly has a kohler in it and its about 3 hp I am told. Is there any way of telling the difference between an RJ35 or 58, 59 etc? This is also supposed to come with a 3ft sicklebar mower and a regular deck. Any things to note when I look at it? Share this post Link to post Share on other sites
neil 2,410 #2 Posted December 9, 2011 rj 35 has the smooth hood with no name on it Share this post Link to post Share on other sites
NYRedNeck 4 #3 Posted December 9, 2011 rj 35 has the smooth hood with no name on it Thanks Neil, Is that the only difference? Should there be belt guards present or any other usuall missing items? Any photos on here of a complete 35? Share this post Link to post Share on other sites
dclarke 4,082 #4 Posted December 9, 2011 Go to the " wheel horse picture gallery" section and look under 1955-64. You can find photos of them there. Share this post Link to post Share on other sites
stevebo-(Moderator) 8,531 #5 Posted December 10, 2011 RJ 35's have the selector speed forward and reverse and the rj58/59 have the gearbox 3 speed with reverse. Share this post Link to post Share on other sites
MikesRJ 558 #6 Posted December 16, 2011 There are a number of significant differences. The 35 has a belt drive system, the 58 has a 4-speed transmission, which is the major one. Take a look at the two manuals: RJ-35: http://www.mywheelhorse.com/graphics/file/Tractors/RJ-35.pdf RJ-58/59: http://www.mywheelhorse.com/graphics/file/Tractors/TR_1958_RJ-58-59.pdf Share this post Link to post Share on other sites
71_Bronco 1,072 #7 Posted December 16, 2011 There are a number of significant differences. The 35 has a belt drive system, the 58 has a 4-speed transmission, which is the major one. THIS! Whenever I look at a small round nose, the first thing I look for is the front axle. The Suburbans have the "M" shaped cast ones, while the RJ's have the straight, welded axles. Next thing I look for is the trans style. The stick in the center, and the 4 speed gearbox (3 forward, 1 reverse), tells me it's more than likely a RJ-58 or RJ-59. The belt drive system was before the RJ-58's, which tells me it is a RJ-35. Just my way of looking at them to decipher what they are. Share this post Link to post Share on other sites
Calebintn 1 #8 Posted December 19, 2011 :text-merryxmas: Well hurry up & go buy it, the waiting is killing me. Share this post Link to post Share on other sites
AMC RULES 37,196 #9 Posted December 19, 2011 IIRC, aren't the frames completely different too? Share this post Link to post Share on other sites
TT-(Moderator) 1,162 #10 Posted December 19, 2011 IIRC, aren't the frames completely different too? Yes - the frame on the RJ-25/35 models is made from a single piece of channel - whether it's extruded "iron", or formed steel plate. It also runs the full length of the tractor. RJ-58/59 frames are the more conventional angle iron "ladder" design which stops just behind the engine mounting location. Side note: RJ-35 models built after the Wheel-Horse trademark became officially registered will have the name stamped in the "grille" portion of the hood. To the best of my knowledge, this happened sometime in mid-1956. 1 Share this post Link to post Share on other sites
AMC RULES 37,196 #11 Posted January 2, 2015 Now there's a view of a '35... you don't see everyday. Share this post Link to post Share on other sites
buckrancher 2,694 #12 Posted January 2, 2015 Now there's a view of a '35... you don't see everyday. WOW Craig you must be really bored to be surfing thru 4 year old threads Brian Share this post Link to post Share on other sites
AMC RULES 37,196 #13 Posted January 2, 2015 You too Brian. Share this post Link to post Share on other sites
squonk 43,777 #14 Posted January 2, 2015 I worked today. No time for the internets. My computer time ws dedicated to getting a chiller running in 30 deg weather Carry on with your Wheel Horsin! Share this post Link to post Share on other sites
AMC RULES 37,196 #15 Posted January 3, 2015 I think for comparison... an RJ-58 frame should be included here too. Share this post Link to post Share on other sites
VinsRJ 723 #16 Posted January 4, 2015 WOW Craig you must be really bored to be surfing thru 4 year old threads Brian I was thinking the same thing.... Share this post Link to post Share on other sites
jackhammer 550 #17 Posted January 4, 2015 Not that I go out looking for these early models but the threads above give me a much better idea of what models I see - 25 or 35 than I ever knew.. thanks all for giving examples and descriptions. it helped this newbie 1 Share this post Link to post Share on other sites
rjg854 12,175 #18 Posted January 4, 2015 I have to agree. That's why I joined this forum also, there's so much to learn from you all. 1 Share this post Link to post Share on other sites
