rdd52 0 #1 Posted December 1, 2011 i just bought a snow blade for my 701 i don't know if it is complete or if it is the right one does anybody have an ipl or user guide for the blade so i can see if it is all there and how it goes on.thank you for your time. Share this post Link to post Share on other sites
TT-(Moderator) 1,169 #2 Posted December 1, 2011 This is the dozer blade offered for the 701. Easily identified by the "X" brace rods and no trip springs: The brackets for mine are still bolted to the tractor. They are nothing more than a piece of angle iron mounted vertically to the front of the square axle housing and secured by two bolts through a backer plate on the back side of the axle housing. At the bottom of the angle iron is a 1/2" hole used to secure the blade frame with a 1/2" bolt. It will be a challenge - and it won't happen right away, but I can probably get picture of the brackets if you need them. Share this post Link to post Share on other sites
rdd52 0 #3 Posted December 2, 2011 this is the one i picked up i finally found my camera to get some pictures do you think this will work without to much modifications i don't want to chop it up.do you know what model wheel horse this is for?thank you for your time. Share this post Link to post Share on other sites
TT-(Moderator) 1,169 #4 Posted December 2, 2011 That appears to be a 6-2111 ~ which is the "more modern" version of the BD-4267. The angle lever & related linkage needed if you want to angle the blade from the tractor seat: Here's a drawing of the rear hitch for that A frame style. Unlike the newer models, the hitch plates fasten to the outer ends of the A frame mounting rod.: I thought I had a picture of the actual hitch, but haven't found it yet. Share this post Link to post Share on other sites
