truckin88 104 #1 Posted November 7, 2011 Guys, I am trying to move my grandfathers 314-A it has sat for 2 years, it will not roll with the trans disengaged (pulled T lever), no ebrake, brake shoe is loose. We need to push it onto a trailer to get it home to work on it. PLEASE HELP!!!!! Tranny is Eaton 700 (lift is an armstrong) Share this post Link to post Share on other sites
Rollerman 290 #2 Posted November 7, 2011 There is no "tow valve" on the Eaton 700. About all you can do is roll it slowly....you will here a clicking. Another option...try to lift one back tire up as you push it up the trailer. I know....sounds crazy, but this will let the diff in the trans free wheel with the unloaded tire spining backwards. Share this post Link to post Share on other sites
Kelly 1,035 #3 Posted November 7, 2011 I've heard if you push the motion control lever forward it help relieve pressure, but I'm not sure if it is true or not. Share this post Link to post Share on other sites
Rollerman 290 #4 Posted November 7, 2011 I've heard if you push the motion control lever forward it help relieve pressure, but I'm not sure if it is true or not. Good point Kelly. I almost mentioned it, but wasn't sure if the was unique to the Eaton 1100 series hydros? :dunno: Share this post Link to post Share on other sites
truckin88 104 #5 Posted November 7, 2011 There is a trans disengage lever like on my C-175 Hydro I had. It basically takes the pulley off the belt. Share this post Link to post Share on other sites
TT-(Moderator) 1,169 #6 Posted November 7, 2011 The two tractors I have owned that had the Eaton 700 would not push no matter what. You'll either have to jack it up or slide the tires. Share this post Link to post Share on other sites
Rollerman 290 #7 Posted November 7, 2011 There is a trans disengage lever like on my C-175 Hydro I had. It basically takes the pulley off the belt. The lever releases belt tension off the pulley so the engine can crank over a little easier without haveing to drag the hydro pump too. It also sets a parking brake when you release the belt tension. Share this post Link to post Share on other sites
Pollack Pete 2,273 #8 Posted November 7, 2011 I had the same thing happen a couple months ago.My 314-A sat outside for several months.I tried to push it in my shop.No-go.I finally kept moving the motion control lever a tiny bit at a time while I kept trying to push.Finally I was able to roll the tractor.Just another Wheel Horse mystery,I guess. Share this post Link to post Share on other sites
truckin88 104 #9 Posted November 20, 2011 new battery, fired up and moved fine...thanks guys Share this post Link to post Share on other sites
